Pushrod cover gasket replacement
Old Jul 14, 2014 | 01:03 PM
ChrisGray91's Avatar
ChrisGray91
Do I have to take the distributor off to change the pushrod cover gasket? Any way of doing it without removing the distributor? Any tips/tricks or warnings I should know about the removal process? 1991 Ford F150 v6 4.9 4x4
Old Jul 14, 2014 | 01:08 PM
David7.3's Avatar
David7.3
the 4.9 is a straight 6 not a v-6. you should be able to squeek the cover by the distributor, with the cap removed. its not a big deal to pull the distributor if you have to just mark it right and keep the engine at TDC.
Old Jul 14, 2014 | 01:11 PM
ChrisGray91
Thanks
Ok thanks for the fast reply man. I appreciate your help.
mgargiullo
15
Oct 11, 2014 06:55 PM
hillcountryflt
19
Jun 26, 2014 11:35 AM
WilleyJoe.62
19
Mar 4, 2014 07:44 PM
joeycarpunk
May 19, 2011 03:55 PM
quincyjr
Apr 12, 2004 04:54 PM
