Subwoofer amp install- tips?
Old Jul 16, 2014 | 06:08 PM
Garrett248's Avatar
Garrett248
Update: I started to prepare for my amp install this weekend. I started to look for a grounding point under the drivers side second row.
I took out one of the seat bolts and sanded the seat bracket down around the hole + I sanded down the contacting face of the bolt.
Will this be good enough for a ground??
I hope this is what you guys were referring to when you said use a seat bolt for grounding.
Old Jul 16, 2014 | 08:54 PM
sessland's Avatar
sessland
At the very least you should sand ALL the paint off if you want to ground it to the seat but that's still not a very good ground.
The seat rail is painted and so is the floor of the truck so there is no bare metal touching between those two. The only bare metal in that scenario is the threads of the bolt.
Old Jul 16, 2014 | 09:13 PM
Garrett248's Avatar
Garrett248
You're absolutely right about the no bare metal touching- that's what it looked like to me when I was taking a look.
After digging through threads it seems like a lot of people have grounded their amps to the seat bolt...I'm assuming the same way I'm doing it? I don't really see another way.
Hopefully someone will respond who has done the same thing or something similar.
Old Jul 17, 2014 | 04:58 AM
kornfanjoe's Avatar
kornfanjoe
I removed the 2nd row entirely for my installation, sanded down the bottom of the seat bracket and the top of the body where it bolts to, and sandwiched my ground lug between the two. I'm running a 360 watt 4 channel speaker amp in that location.
For lower wattage applications you should be fine, if you aren't getting enough ground the amp will cut out and stop playing for a second or two and you will notice it. If that happens turn it down some until you correct it.
Old Jul 17, 2014 | 05:54 AM
Archion's Avatar
Archion
Veteran: Marine Corps
My my 300.1, grounding to the seat bolt is just fine. I didn't even sand, and I push it hard. If you are going high power (~600+) as mentioned above, you will want a good solid metal to metal ground. I would lift the carpet and make one. But don't go too far for it, a long ground can introduce noise into the system, like an antenna. I like to keep my total ground length under 15" max.
Old Jul 17, 2014 | 06:04 AM
Garrett248's Avatar
Garrett248
Hmmm I'm a little nervous my amp is 1,100 watts but it will be pushing 550watts RMS (at 2ohms)
Old Jul 17, 2014 | 09:26 AM
Archion's Avatar
Archion
You better do a good ground, and an equally good supply.
Old Jul 17, 2014 | 01:40 PM
Garrett248's Avatar
Garrett248
That's what I'm trying to do!
Has anyone done an install like I showed in my pictures??
Old Jul 17, 2014 | 09:51 PM
sessland's Avatar
sessland
I don't mean to come off as a dick, but....
Who cares how many people do it the seat bolt way. It is NOT a proper ground period.
I have personally had a pretty scary experience with a grounding issue and I wasn't running any crazy high power amp. (It was an old school Soundstream Continuum for anyone that is interested)
Another fun fact about bad grounding. If your ground should happen to come loose for any reason it will make super cool sparks each time it touches metal and it won't blow the power fuse. This is the same way that arc welders work. We've all heard about people welding with a 12v car battery and a coat hanger when stranded right? No amp necessary
Ask me how I know...
Old Jul 18, 2014 | 01:38 AM
Peace2Peep's Avatar
Peace2Peep
Find a good spot on the chassis and place your ground. DO NOT use this bolt. That would not be smart. It's never convenient to do something correctly, but it will give you safety and piece of mind.
Old Jul 18, 2014 | 05:37 PM
superdave02f552's Avatar
superdave02f552
Curious as to what is sooooo bad, if the paint is cleaned away from the floor and the seat bracket
That connection will be fine. As far as sparks flying and bursting into flames how often do seat bolts come out to let the wires flop around to arch that bad. BUT on the battery end I would add an equal gauge wire from the battery to the chassis
Old Jul 18, 2014 | 07:13 PM
superdave02f552
Correction body
68bluebeast
Oct 10, 2012 04:58 PM
Jbru167
Oct 18, 2007 09:11 PM
SoCalSuperCrew
2004 - 2008 F150
Jul 2, 2004 10:02 PM
1yamman350
Jan 25, 2004 11:12 AM
svn2002s
Jan 5, 2004 09:19 PM
