Sponsored by: Auxito
Rear Slide Window
Old Jul 10, 2003 | 09:35 AM
im4unc's Avatar
im4unc
Unhappy Rear Slide Window
Hi everyone, I am new to this site but there is a wealth of information and knowledge that I have read already. I have a 1997 F150 Lariat Ext. cab. Has anyone else had the rear slide window leak? Reccomendations on how to fix as I tried to tighten the bolts that hold the window in but nothing. Thanks for the help.
Old Jul 10, 2003 | 09:36 AM
thel's Avatar
thel
Rear Slide Window
How does the weatherstripping look? Is it brittle?
Old Jul 10, 2003 | 08:22 PM
Racerguy's Avatar
Racerguy
Rear Slide Window
Hi im4unc and welcome to FTE
Ford came out with a new gasket to cure the leak. You remove the window and replace the gasket. Your dealer should stock it or be able to order it for you.
Old Jul 11, 2003 | 08:55 AM
im4unc's Avatar
im4unc
Rear Slide Window
Thanks for the advice I will get the gasket and do it this weekend.
Old Jul 11, 2003 | 09:04 AM
im4unc's Avatar
im4unc
Exclamation Rear Slide Window
I just spoke with Ford parts and they said That the gasket is part of the window and I need to replace the whole thing(sounds like BS to me). Any ideas racerboy?
Old Jul 11, 2003 | 09:15 AM
Racerguy's Avatar
Racerguy
Rear Slide Window
Have them look at TSB 01-1-11.
See if they will photocopy it for you too so you have the instructions.
Old Jul 14, 2003 | 07:51 AM
im4unc's Avatar
im4unc
Rear Slide Window
What is TSB 01-1-11?
Old Jul 14, 2003 | 08:12 AM
Racerguy's Avatar
Racerguy
Rear Slide Window
It is a Technical Service Bulletin that all Ford dealers get sent to them or have access to online.
This one gives instructions on replacing the seal around the window.
It is too long to post it here.
Old Jul 14, 2003 | 08:48 AM
im4unc's Avatar
im4unc
Rear Slide Window
Roger that, thanks for the help
Old Aug 6, 2003 | 08:02 AM
elitper's Avatar
elitper
Rear Slide Window
Racerguy,
Is there any way I could get you to fax or E-mail me a copy of that TSB??
Old Aug 6, 2003 | 02:20 PM
jmr1653's Avatar
jmr1653
Rear Slide Window
IM4UNC, First of all, sorry about that, go UK!!
Let me know how the window seal works out. I have a 97 and it leaks as well. Thanks
