Help needed!
Old Jul 13, 2014 | 06:50 PM
meadowa22's Avatar
meadowa22
Help needed!
Hello-
2003 Ford Expedition Eddie Bauer 5.4L. My issue is this....When I tow my travel trailer (4200 lbs.) or my utility trailer(loaded) I get a clunking/grinding from my truck. I am not surely exactly were the noise is coming from. It seems to only happen when going up a hill and around 60 MP. It happens in overdrive or even when the overdrive is off. When I hear the noise, I ease off the gas and the noise goes away. I have replaced many things in the front end of the vechicle in the last year but I still have the noise. Thank you for any help on this matter and if more information is needed, please let me know.
Old Jul 13, 2014 | 09:07 PM
alloro's Avatar
alloro
I would first suspect the rear differential.
Old Jul 14, 2014 | 04:32 PM
r2millers's Avatar
r2millers
To alloro's point, the wheel bearing seals are known to leak after many miles and use gear oil. I'd get under the rear end and look for seal leakage and I'd check the diff fluid level. I would also check the U joints to see if they're bad.
Either of those would be more pronounced when pulling a load.
karimpoor
26
Sep 15, 2019 03:54 AM
karter81
2004 - 2008 F150
May 11, 2015 09:17 PM
5walleyes
Mar 14, 2014 10:36 PM
srozing
Apr 18, 2012 08:45 AM
Miketnf150
Mar 27, 2009 02:59 PM
