Aerostar Ford Aerostar
overheat/no start
Old Jul 27, 2014 | 04:13 PM
Tigauto's Avatar
Tigauto
Pull the dip stick and smell it? Do you smell fuel? Dump the oil if head gasket gone you will see antifreeze come out first before oil. If no antifreeze you may have seized the rings in the piston. Or it's just badly flooded from cranking. I would have a tech do HC test on cooling system. There should not be any hydrocarbon in the cooling system, tell him you want the HC test results. If HC in cooling system I wouldn't do just the heads! New heads on old block asking for trouble depending on miles.
4drf350
1966 - 1977 Early Broncos
Jun 23, 2013 08:12 PM
knoxvegasdaddy
Sep 15, 2011 03:36 AM
Steve Bennett
3.8 & 4.2L V6
Jan 3, 2010 06:17 PM
jefnf
Nov 27, 2007 12:31 PM
Xwarrior86
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jun 21, 2007 07:32 PM
