Which motor
Old Jul 10, 2003 | 03:41 AM
dhigh45's Avatar
dhigh45
Question Which motor
Ok I need opinions.I have a 1960 p/u going on a 77 4x4 frame.Now what is the prefered motor, I have a 400m(bad crank) and a 352 built like a monster(twisted original frame when I lifted front wheels off the ground)I,ve heard the 400 has some oiling and reliability problems. The 400 would be the easy install since it came out of the 77(I'm using complete running gear from 77) Is there a better option 351C ???tell me what you think. more info-3/4 ton 4x4 long bed (heavy) for serious mountain/pulling/working Thanks everybody.
Old Jul 10, 2003 | 05:54 AM
4tl8ford's Avatar
4tl8ford
Which motor
If you have the "Good" 400, there can be a lot done with it, very strong, lotsa torque.
Check out the Engine Fourm: https://www.ford-trucks.com/forums/f...?s=&forumid=54
To tell which is the good engine.
WARNING do not use the term "400M"!
