CPP Power Booster (need help)
There is nothing wrong with a pressure switch in fact it is really a more accurate(not that it matters for tail lights) because it only come on if there is pressure, not just when you push the pedal like a position switch which are cheaper for manufactures to install.
<a href="http://s1035.photobucket.com/user/SandersBallistics/media/Mobile%20Uploads/20131107_182911.jpg.html" target="_blank"><img src="http://i1035.photobucket.com/albums/a440/SandersBallistics/Mobile%20Uploads/20131107_182911.jpg" border="0" alt=" photo 20131107_182911.jpg"/></a>
I also do not think you will need residual pressure valves unless you plan to lower it quite a bit later on. I did not install any but they can't hurt anything I guess.
Good luck with the kit.
Getting ready to mount the booster while dad bench bleeds the MC.
Leveled it and clamped it in place using the proportioning valve bracket to get all the air out.
Cut a hole in the floor so we could fill/see the fluid.
I'll probably weld it back in and get the remote reservoir kit from CPP (wish I would have done that from the start).
No one this close to the arctic circle had this piece so I had a hydraulic shop make up the hose and I used the old breather and Y fitting (after cleaning it out of course).
As recommended I made my own grommets when needed.
Used these when needed as well.
I did use residual valves.
Everything fit great and they work even better!
15" wheels likely off of a 70's truck.
Still haven't figured out what to do with the brake lights. This did not work (and looks horrible as well).
I like the looks of that one from Mid Fifty, so thanks for sharing! Mine is not leaking but it just doesn't work. It may need one that works off of a lower amount of pressure. CPP makes one that only needs 45 lbs, but I saw another that requires even less. I might get that kit from CPP that Jules the Great has and add that pressure valve that runs off of a lower amount of pressure. Or just mount one to the floor and call it good.
For those that have installed the switch on the floor: how much travel will they accept? My brakes work great, but they do travel a couple of inches at full stop and most of those switches (except the Mid Fifties one) don't seem to allow more than about 1/2" or so. What am I missing? I'll update this when I get it all figured out.
I didn't have any leaks once everything was hooked up, but I didn't flare anything either. I just bought lines that were close to the right length (longer) and made an extra bend here and there. It's not as sexy as it could be, but as you can tell I'm building a driver not a show truck. It caused me to have a couple of unions, but since they were all factory cut they seem to be holding great.
To bend my lines I actually used a couple of pulleys that I had sitting around. Those green/grey lines from NAPA are very forgiving and do not kink very easily. I highly recommend them.
Thanks again everyone, and I hope you get to drive yours soon if you aren't right now.
Gotta love it!
On the mechanical brake switch, they work on release, not compression. So you just mount it so that the pedal pushes it slightly when it isn't in use, then releases (activates the lights) when you push on the pedal.
CPP now sells this fitting separately. not very expensive. Seems to be CPP's MO these days, sell every part separately so you don't notice how expensive the entire setup is until after you buy the basic part and have to then buy all the rest of the needed parts to actually use it.
I ended up ordering the one from Mid Fifty that Axracer found.
I did see the one that CPP sells separately now,and Speedway sells a setup too that comes with an adapter that looks a lot like the one I put on my stock switch. I think the one I ordered from Mid Fifty will work out fine. I'll post some shots when I get it put in.
That flaring kit from Eastwood looks and sounds like the one to get, but I just couldn't justify droping the cash. It took a bit to get pre-cut lengths that would work for every side, but it was well worth it.
Thanks again everyone for all your advice and tips. I learned a lot from this thread and used much of your advice for my install. Enjoy your rides!
It took a bit to get everything all adjusted perfectly and in the right place. I ended up putting it under the floorboard.
I don't really trust the tiny nut and bolt to hold the elbow in place for long, so I will have to seal it up so it won't come loose while I'm on the road.
Thanks again to everyone for their help!
Your brakes look great & a nice tutorial as well!
Nice.... It looks like your first post on brakes around July 10th &
your latest was today - (4) months - now that sounds like one of my projects! How does it drive? Everything feel good? What are you tackling across the winter?
Ben in Austin
1950 F1
It drives absolutely amazing! It'll be much safer now for me and the boys. I'm currently sanding off that old gray primer and exposing the original paint/patina/primer underneath. Then I'll take it to the shop and get it cleared. When it's back I'm putting in seatbelts and upgrading headlight wiring and some other misc things. I'll do up a little post in a couple of months to show off his new/old paint job. Oh, and I'm about to pick up a T5.........
