manifold vacuum
Old Jul 9, 2014 | 02:53 PM
flaty 72's Avatar
flaty 72
manifold vacuum
Just wondering what the normal manifold vacuum is for a stock 1972 360FE?
Old Jul 9, 2014 | 05:01 PM
351Cleveland C4's Avatar
351Cleveland C4
Each engine is different, the biggest factors are idle speed and fuel mixture and ignition timing. But internal wear and condition, What kind of intake/ exhaust system, camshaft profiles, valve tolerances, and everything else also play a part. Even your elevation above sea level.
But on a stock 360 that is tuned properly, I would think right around 20" would be expected. The more the merrier when it comes to vacuum.
Old Jul 10, 2014 | 03:41 PM
flaty 72's Avatar
flaty 72
Thanks for the info mine is 15Hg with stock cam, Edelbrock performer.
summit racing carb.
Old Jul 10, 2014 | 05:03 PM
351Cleveland C4
That seems low. My 351C with the edelbrock package sucks 18".
Try tuning the mixture and timing with the vac gauge hooked up. Go for the highest reading you can get.
Old Jul 14, 2014 | 04:07 PM
flaty 72's Avatar
flaty 72
I will check that out.
Stephen Hayhurst
Jul 9, 2019 09:44 AM
bobs 80 f250
Jun 14, 2019 01:06 PM
78 Ford F150 460
1978 - 1996 Big Bronco
Jun 7, 2017 10:47 PM
Tedster9
Sep 1, 2016 09:57 PM
outcrydrummer
Jan 2, 2014 01:26 PM
