212 code only and stalling
Old Jul 8, 2014 | 08:20 AM
spyder0382's Avatar
spyder0382
I only have this code truck runs good then acts up and stalls I have replaced the fpr and checked no fuel coming out once the vacuum line is off. The truck originally had the Grey Idm from Po I put black one back in ran great for a while. I had the pcm ' s capacitors replaced I replaced the distributor with one from Bennett auto. Now all of a sudden this is happening. How do I test the idm. I think this is what is causing it due to the Po replacing it and not putting any thermal paste on it where it seats to the heat synch
Old Jul 8, 2014 | 08:30 AM
timbersteel's Avatar
timbersteel
Ok, if it's overheating, an easy trick would bento take the wife's hairdryer or girlfriends and heat the module up. Do this after it has a chance to be cold started, like overnight or for several hours.
Next step would be to run by Radioshack and get some thermal paste if you believe it's not there.
Old Jul 8, 2014 | 09:25 AM
subford's Avatar
subford
DTC 212 indicates a loss of IDM input to the PCM.
Possible Causes:
-- Open harness circuit.
-- Shorted harness circuit.
-- Damaged Ignition Control Module (ICM).
-- Damaged Powertrain Control Module (PCM).
As long as you have the Black ICM in your 1994 truck.
Old Jul 8, 2014 | 10:19 AM
spyder0382's Avatar
spyder0382
I put thermal paste on heat synch just wondering how to actually test it or if there is a pin point test for 212 code
Old Jul 8, 2014 | 10:33 AM
rla2005's Avatar
rla2005
Code 212 is listed as a Continuous Memory (CM aka historical) only code. Did you clear the codes after installing the correct ICM?
Old Jul 8, 2014 | 10:55 AM
spyder0382's Avatar
spyder0382
Yes I did but I installed the idm back in November and when I cleared the codes I let it sit over night with battery disconnected after pulling jumper from test port drove around for half an hour then I started to act like it was losing fuel all this happened after filling rear tank and adding 30 bucks to front
Old Jul 8, 2014 | 11:04 AM
subford's Avatar
subford
Was the ICM you replace a Motorcraft brand?
I have not seen any Motorcraft brand black ICM go bad but they do get replaced.
I pick up Motorcraft black ICM's at pick & pulls and all that I have tested are good ones.
If you have another brand I would start by replacing the ICM with a Motorcraft brand Black ICM.
Old Jul 8, 2014 | 11:09 AM
spyder0382's Avatar
spyder0382
When I bought the truck it had a Grey motorcraft one in it the original black one was in the glove box I installed it back in November. It's worked ever since. How do you bench test it.
Old Jul 8, 2014 | 11:16 AM
timbersteel
What year truck are we diagnosing?
Old Jul 8, 2014 | 11:19 AM
subford's Avatar
subford
I swap them out on my truck and drive it for a while is how I test mine. There are write ups on the net on how to do it but unless it is burned up those will not help much.
The test would also need you to heat the ICM up to be very meaning full.
Old Jul 8, 2014 | 11:20 AM
spyder0382's Avatar
spyder0382
94 f150 e40d 4.9 don't know if it's the gray or black Is the correct module but Lile I said the black one was installed in November and ran fine since when I got the truck there was a mess of stuff needed to be done
subford's Avatar
subford
Your truck takes the Black one.
Old Jul 8, 2014 | 11:21 AM
spyder0382's Avatar
spyder0382
It just happened all of a sudden
Old Jul 8, 2014 | 11:34 AM
spyder0382's Avatar
spyder0382
What voltage should I get at the spout
Old Jul 8, 2014 | 11:47 AM
subford's Avatar
subford
Why do you ask about the SPOUT test?
CHECK SPOUT SIGNAL
Crank engine.
Measure voltage between PCM Pin 36 (SPOUT) and battery negative post during crank.
Is voltage between 3.0 and 6.0 volts?
If yes EEC system is OK.
