Quick question about carbon monoxide
Old Jul 7, 2014 | 09:55 PM
351Cleveland C4's Avatar
351Cleveland C4
Just went down and had the truck smogged. It did very well except on Idle carbon monoxide.
I drove it in set just as it is every day. I have the idle a little bit on the rich side so it starts easy. Which is why I think it failed.
So if I lean it out a little, and turn the idle speed up a bit, that should solve the problem correct?
Old Jul 7, 2014 | 10:36 PM
orich's Avatar
orich
Having your air/fuel jets in to make it run richer, you say it makes it start easier.Well what ever works for you. So why didn't you reset those jets.?
You got a start listening to your inner voices that flash through your head more often.
Hook up your vacuum gauge and retune it. Engine should be warmed up good. 180*-195*thermostat should get you by. Also a clean air filter..
Orich
Old Jul 7, 2014 | 10:40 PM
351Cleveland C4
Yea, I could have tuned it prior, but I wanted to see what I was at with my normal settings. It was actually pretty good. Just not quite good enough... I get 2 tries for each test, so I'm still good. This is the first time sniffing this engine, so I wasn't quite sure what it was doing.
I'm confident that I already fixed the problem. I leaned the screws out 1/4 turn each and increased the idle speed to about 800rpm. I'm going to go again first thing in the morning and try again.
Old Jul 7, 2014 | 11:19 PM
orich's Avatar
orich
I've heard of guys adding some alcohol or acetone and even MEK to try to pass.
I don't know if that got them to pass tho.
I use MEK mix with some high octane gas back in 60's in my racing days.
Good stuff if you mix it right!
Orich
Old Jul 9, 2014 | 01:30 PM
351Cleveland C4
Just went and tested again. Passed no problem.
Old Jul 10, 2014 | 01:58 PM
JEFFFAFA's Avatar
JEFFFAFA
Congrats 351. Flying through on the 2nd go-'round is a beautifull thing.
Old Jul 10, 2014 | 02:00 PM
351Cleveland C4
Yea. Now I don't have to worry about it for another year.
Cedarghost
Mar 26, 2016 08:13 PM
86LariatXLT
Dec 6, 2012 08:51 AM
vls
Jan 1, 2012 06:52 PM
weldman
Aug 22, 2001 08:09 PM
75highboy
Dec 23, 1999 03:55 PM
