IDI vs PSD footprint
Old Jul 7, 2014 | 08:14 PM
Ford_Six's Avatar
Ford_Six
I am stuck sitting in Texas working the oil fields right now, but am plotting my next build. 68-70 body with a 70s Supercab extension grafted on, sitting on a late 80s/early 90s frame with an IDI and ZF.
I'm having a really hard time finding the frame donor though, so next week I am going to look at a 95 with everything I want except it's a PSD. I want the IDI because they are much cheaper to fix, and can be tuned to similar power levels without too much trouble. I also have one in the van, so having two vehicles with the same engine reduces the spare parts I have to have hanging around.
How hard is it to go from an early PSD to an IDI? I know the PSD has tons of wiring, but aside from that is everything pretty much bolt in?
Old Jul 7, 2014 | 09:17 PM
Sycostang67's Avatar
Sycostang67
Thats what it sounds like, PSD drive train will drop right in, you just have a bunch of wiring to install. Dont forget the gas pedal due to the drive by wire setup those things use.
Old Jul 7, 2014 | 09:53 PM
RacinNdrummin's Avatar
RacinNdrummin
Everything should drop right in with no issue.
If your grafting a cab together, you have bigger fish to fry ...
Old Jul 7, 2014 | 10:09 PM
Ford_Six's Avatar
Ford_Six
Oh, I know. I really wanted to avoid reworking the firewall for pipe clearance too but if I go this route I'll pretty much have to.
I forgot about the pedal, I may have to do something like International did with some of their trucks and run a cable to a box to operate the position sensor.
As far as wiring, since it's a manual there should be much less but I'm thinking of modifying as needed to put the computer on the right fenderwell or maybe up behind the glovebox but I want to make it easily removable for the IDI swap.
Are the engine perches the same?
redneckbronco80
Nov 12, 2023 02:38 AM
brozenhimer
May 15, 2015 03:50 PM
Fordman96
Michigan Chapter
30
Oct 11, 2013 06:47 PM
megawatt00
40
Apr 3, 2008 09:52 PM
frnkln2003
16
Apr 19, 2007 03:21 PM
