shift boot
Old Jul 7, 2014 | 04:27 PM
Necromancer's Avatar
Necromancer
shift boot
I just bought a new shift boot (with the included mounting plate) for my 1994 F150 4.9L Manual. I have a silly question: after removing the shift **** - how the heck do you get the new one on? just slide it down? do I have to remove the entire shifter pole?
Thanks in advance...
Nec
Old Jul 7, 2014 | 11:12 PM
trdsmn's Avatar
trdsmn
Yes, you must remove shifter.
Raise the boot and you should see two bolts attaching shifter to stub shaft protruding from transmission.
Slide old boot off and slide on new one. Reinstall shifter and fasten boot trim ring to floor.
I recently changed mine (mechanic destroyed trim ring during new clutch install) and the foam inside the shifter disintegrated. Found another boot assembly with good foam and changed it again.
Unbelievable the amount of heat that radiates from that boot without the foam.
Good luck
Old Jul 7, 2014 | 11:52 PM
trdsmn's Avatar
trdsmn
Post script: previous instructions are for ZF5OD.
Your f-150 likely has M5OD.
For M5OD there is one bolt connecting shifter to transmission stub shaft.
Old Jul 8, 2014 | 07:22 AM
Necromancer
cool. thx!
Old Jul 9, 2014 | 07:30 PM
Necromancer
Got the shifter off today. Figured I'd also replace the bushing since I was already there and it need it badly.
So, does the secondary boot - the one under the main boot - slide under the carpet or under the lip of the trans tunnel, too? I know, stupid question. My gut tells me it just slides under the carpet, but...
1994 F150 4.9L Manual 300 XL Standard Cab.
Thx in advance.
Nec
JEMacEwan
2009 - 2014 F150
Apr 30, 2016 06:13 PM
octaneforce
May 3, 2011 08:31 PM
powerstrokedieselfan
Oct 16, 2010 04:35 AM
razor_jim
Aerostar
Jan 9, 2004 05:45 PM
1996F150kid
Sep 26, 2003 05:17 PM
