shifter stick removal for clutch replace
Old Jul 6, 2014 | 06:30 PM
malundquist's Avatar
malundquist
I have a 1986 F150 six cylinder with a four speed (with granny gear) trans. I am replacing the clutch and I'm stumped on how to remove the shifter stick from the transmission in order to pull the transmission out. I am a first timer on a pickup clutch replacement. Thanks, Mark
Old Jul 6, 2014 | 09:32 PM
carguy94's Avatar
carguy94
does your shiftier have a tapered cup on the bottom after the boot has been removed. should be able to push on and twist or it should pop up off and let the shiftier pull out
Jeremy12ga
Dec 31, 2017 12:20 AM
donberry
Nov 6, 2011 03:55 AM
rosett
Aerostar
Jun 13, 2011 01:54 PM
m9massie1
Dec 30, 2003 11:59 AM
