Spindle Arm Ball Replacement
Old 12-04-2010, 08:04 PM
eman92082's Avatar
eman92082
eman92082 is offline
Howdy Friends,
'49 1/2 ton - Stock Front End
The Ball on my Spindle Arm is slightly worn and since I've rebuilt my Drag Link and have a new Pitman Arm, I thought it might make sense to change it. The sucker is seriously staked in place.
I note that the exploded view of the assembly shows a tapered part (PN 3131) that is held in place with a Castle Nut and Cotter Pin. Has anybody replaced one of these and if so, was the hole tapered or did you have to have it taper-reamed?
Thanks
Dawg-a-Saurus
Old 12-04-2010, 10:17 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
The Parts CD says that F-1's, '48 - '52, had an integral ball. '53 -on and some of the heavier '48-'52's had ***** that were replaceable. Does yours have a castle nut? Not like the Parts CD is always right.
Old 12-04-2010, 11:13 PM
eman92082's Avatar
eman92082
You are right Ross. My Bad.
I was looking at the wrong illustration on my CD. Not the first time I've done that either. Mine does indeed match illustration P552.
I measured the ball with a Mike and although it looks really worn, it's really not as bad as it looks. It's only worn .020 and there is no galling. So I think I'll go with it.
Thanks for the help pointing that out.
Ernie
Old 12-04-2010, 11:49 PM
underthebridgejim's Avatar
underthebridgejim
underthebridgejim is offline
FTE fan
Glad to hear yours is ok, i had to drill out and ream mine. Then weld in a new ball. I guess i could have also rethreaded for the new ball, hind site is always 20/20. oh well it will out live me. ha ha! (jimmy)
Old 12-05-2010, 08:32 AM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
Press fit - I've seen them heated and smacked with a hammer, acted like a missle launcher - I've drilled all mine out.
There are some replacements with threaded ends.
Old 12-05-2010, 10:25 AM
bobbytnm's Avatar
bobbytnm
bobbytnm is offline
Roast em' if you got 'em
Received 3,841 Likes on 1,840 Posts
Dawg,
Just run any old bolt through the hole, drop the drag link on it and make several wraps around teh whole mess with some bailing wire andhead out onto the freeway.....you'll be fine.
You can press them out easy enough. When I built my steering I made made my own link between the pitman arm and the steering arm using the Toyo parts. I ended up pressing out the Ford ball stud and using the Toyo ball stud.
I think I've seen the ball stud inseveral catalogs from the usual vendors, LMC, etc
Bobby
Old 12-06-2010, 09:16 PM
wulleebullee's Avatar
wulleebullee
wulleebullee is offline
I recently replaced one on a 52 F1. First, I ground off the bottom of the ball stud flush with the spindle arm, then drilled it out. Next, I pressed in the new one, heated the bottom that protruded through the arm and star-brad it with a chisel/punch. I found it at Early Ford of California decently priced.
Old 01-27-2014, 12:43 PM
jimcar-9's Avatar
jimcar-9
jimcar-9 is offline
Hey guys
I just borrow this thread.
56 stock front suspension, would "wulleebullee" way be the way to go for me? The new stud has a steering axel splines look a like so a figure it needs to be pressed in and then heated and "forged" to lock it in?
Old 07-08-2014, 10:13 PM
f100 1957's Avatar
f100 1957
f100 1957 is offline
Do you have the parts number fo spindle arm F100 1957 LH
thank's
overlandexpress
19
10-08-2021 07:27 AM
Wes(MI)
Large Truck
02-25-2017 03:40 PM
pezsox
02-10-2017 03:13 PM
ktm4012
03-10-2016 08:14 AM
Corn Fed
24
11-09-2013 07:49 AM
Quick Reply: Spindle Arm Ball Replacement
