Intermittent hard starts
Old Jul 6, 2014 | 11:39 AM
brokersteve's Avatar
brokersteve
I've been dealing with this issue for a while now, and I've finally had enough. I have a '78 F150 4speed, with recently built 400 (year and half ago). It has a recently rebuilt Edelbrock 1406 600cfm, New filter, new Holley fuel pressure regulator set at 5.5 psi, new fuel lines, new pump, new 40 gallon tank, with new sending unit, etc. The problem started well after all these items were installed. Truck was running great , then problem started out of the blue a few months ago. It acts starved for gas and takes many pumps before it fires. A couple times, it has taken several minutes before it starts. Always runs great once started. I have a 1" phenolic spacer, so I don't think the fuel is boiling out. Problem normally happens when completely cold, but not always. It sat for two days, and fired right up with one pump, then the very next day, I could not start it until I sprayed starting fluid in bowl. When I manually work the throttle linkage, fuel sprays out of the two diagonal nozzles at front of carb (can't remember name). These are the only nozzles where it is supposed to come out, right? Any ideas what the problem may be here? Always idles just fine once started. One more thing, the choke seems to be 3/4 shut until warm. Electric choke. Sorry for the long post, but wanted to make sure I gave all the info I could think that may help.
Old Jul 6, 2014 | 04:25 PM
4x4 Bart's Avatar
4x4 Bart
Have you checked the rubber fuel lines. They could be deteriorating internally from ethanol and becoming blocked or small particles of rubber are making their way to the carb needle valve.
Old Jul 6, 2014 | 05:10 PM
brokersteve
Yes, all new fuel lines, hard and rubber. Plus, I run ethanol free gas. I've started about five different times today and aside from the first time, it has fired right up each time. I'm at a loss.
Old Jul 6, 2014 | 07:38 PM
OldMetal's Avatar
OldMetal
Whats your timing set at? The ford recommended setting is for sea level, sounds to me it good be a little too far advanced
Old Jul 6, 2014 | 08:17 PM
brokersteve
I don't recall at the moment, but I believe it is 32 degrees. It has not been changed since well before the problem started though. I will try to check again soon.
Old Jul 6, 2014 | 09:59 PM
redroad's Avatar
redroad
It's important that you narrow down whether you think it is starving for fuel or it is being flooded by heat soak ..
Is the distributor the original duraspark II ?
Stepney
Feb 23, 2018 02:56 AM
Floggit
Dec 22, 2013 04:52 PM
Rickpwjr
Nov 6, 2011 01:18 AM
Josh79
Feb 14, 2008 04:08 AM
andrewasl
Oct 7, 2006 07:39 PM
