I am thinking of a 30MM from a F250 but I don't have Blocks between my axles and springs.
Is the fact that I am 2" lower going to make the Bar not fit?
Thanks
Thanks
I don't see why it would, but I guess it depends on how you got 2 inches lower... so spill it
Thanks
I think the worst thing you might find is that the ends of the bar point down slightly from parallel with the frame due to your removing the 2" blocks from the spring packs. Not a huge deal and you would still feel the benefits from the bar. You could have the end links shortened by a welder if you want or find a set from a two wheel drive rig as they don't have those blocks you took off. I fabbed up longer beefier end links for my old style Hellwig after I did my modded spring swap and gained 4" of lift, my bar ends are level with the frame now.
thats great there is a Kenny u-pull near me that has a F350 and the box is gone and the sway bar was there when I last checked.
There price for a sway bar is only $3.99
Cool! Be sure to get everything associated with it, all the bolts and brackets and such.
Seems high, especially if the bed is already removed. I would skip it, first post up the location of this yard so we can all make a mad dash for it "Rat Race" style though
Does anyone know what year SD sway bars will fit?
Thanks
I would assume any rear that shares the same body as ours. The frame isn't exactly the same as ours but the basics are the same the rest of the way through and since this doesn't go on the frame it should be fine. Someone will give you good hard numbers though
