At a fork between suspensions!
Old Mar 19, 2015 | 09:44 AM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
The CV and jag swap both allow for big brake kits easily. You can use high spec mustang or charger parts to get there. You jut need a bracket to move the caliper out.
Old Mar 19, 2015 | 10:41 PM
Chuck64's Avatar
Chuck64
Good to know!
Thanks! I will fill in on the progress...
Old Mar 31, 2017 | 10:20 AM
RacerJames's Avatar
RacerJames
Resurrecting this old thread because I did an Aerostar front end swap. Yes, it changes the wheel bolt pattern, but, if you then do the T-Bird IRS and add the Mustang rear hubs to it, all your wheels will match again. The aerostar is almost a bolt in, I removed the trans crossmember and installed a 351W AOD combo. I had to fabricate motor mounts, and I used the trans mount crossmember from a '68 T-Bird (because I had one). I did a power brake booster and steering column swap from an '81 F-150 at the same time. Good thing the steering column is a tilt wheel because it would be in your lap otherwise. I'm still refining that part of it because there is an interference point between the fuel pump, steering shaft and oil filter. I have to use the short filter, and I rerouted fuel lines slightly to clear the steering shaft.
A little research will reveal that the stock Aerostar and the '90s T-Bird weigh around 4000 lbs which is the same as my '64 short wide. I have continued to use my truck as a truck and it seems to be sooo much better than it was originally. it handles better, stops WAY better, and works hard as a racecar hauler, dirt mover, appliance hauler etc.
If folks are interested, I can post pics later.
Old Apr 3, 2017 | 03:22 PM
RangerMercMan's Avatar
RangerMercMan
I would like to see some pics thanks
Old Apr 3, 2017 | 05:38 PM
RacerJames's Avatar
RacerJames
When I get to be home while there is still daylight, Ill post pics of the front end.
The rear is still in the works but, I have a link to a site which makes a mount kit here:
www.truckirs.com
Old Apr 3, 2017 | 05:40 PM
RacerJames's Avatar
RacerJames
There is a pictoral of what I plan to do here: TBird IRS into an F-100 Pickup
Old Apr 17, 2017 | 03:45 PM
RacerJames's Avatar
RacerJames
Finally got some pics of the Aerostar front end in my truck
Redneck steering shaft and bracket
upper control arm mounts, engine side
Lower control arm, Driver's side
left inner tie rod boot, and steering shaft
made an extender box for the steering column and brake booster
Clearance issues with the fuel pump and oil filter
the stance of the truck with original rear end and Aerostar front end
Left side upper control arm (had to reach around the tire for this shot, sorry for the blur).
Old Apr 17, 2017 | 03:51 PM
RacerJames's Avatar
RacerJames
I thought I'd add that I did this swap in early '03 which is why I didn't do the CV swap. there weren't any available then. That's also why everything under the hood is dirty, it's been 14 years already! Guess I should wash it more often...
halltm
Nov 15, 2017 05:59 PM
ff604
May 16, 2012 12:02 PM
wallster
Feb 3, 2012 08:48 PM
moonlightdriver
Jul 6, 2007 06:28 AM
JoeKnows89
13
Sep 5, 2004 10:20 AM
