Change transmission & rear end oil
I have a 1988 Super Duty, w/ 4 speed manual transmission, I want to change the transmission & rear end gear oil. I have been asked why in the past, mostly choice, as the vehicle was not serviced or maintained by the original owner, before I bought it, and i don't know what kind of abuse it has had.
How many quarts does the Transmission hold, how many quarts in the rear end?
Also if anyone has a good method to change the gear oil I would appreciate it. Draining is no mystery.
thank you.
thank you.
I changed both on my 94 f150 automatic. The transmission was kind of a pain since I had to unbolt the entire pan, make sure you have a large oil catch if thats what you have to do. For the rear end gear oil I took off the whole cover since I wanted to check something out in there anyway, so thats how I drained it but filling it back up was tough, if I remember correctly it took me about 3 quarts in the rear end, but I have a 1/2 ton pick up not a super duty so I'd investigate that if I were you. And those were the reasons I changed mine mostly, not because I didn't know the previous owners service records, I just wanted to change them and now am glad I did. Good luck!
pburress
02-25-2012 09:57 PM
gofast51004
30
10-26-2008 06:08 PM
