VIN location
Old Jul 9, 2003 | 04:59 PM
bronco460's Avatar
bronco460
VIN location
I am new to this column, and I posted a quetion a few weeks ago. Thanks for the replys. I have a 1978 F150. Is there anything that the hwy dept. can go by to identify these trucks? My door has been changed, and the metal tag from the firewall is gone.
Thanks, Ricky.
Old Jul 9, 2003 | 05:16 PM
Matts72's Avatar
Matts72
VIN location
There is a VIN stamped into the frame rail on the passenger side near the front of the truck. It could be either on the outside or inside of the rail. I would attach a bronze brush to a drill and scrape off the rust and dirt buildup from over the years. If you still can't see it try a piece of paper and some charcoal or graphite. That should bring it out.
Old Jul 9, 2003 | 07:16 PM
ranger429's Avatar
ranger429
VIN location
they also put an id plate with the vin number on a plate and riveted it to the front of the passenger side bed. from under the truck look at the bed by the cab, mine was located on the pass. side between the cab and the bed.
Old Jul 9, 2003 | 07:55 PM
Colossus's Avatar
Colossus
VIN location
What about the data plate inside the door jamb? Does yours not have one?
Old Jul 10, 2003 | 12:29 AM
Mil1ion's Avatar
Mil1ion
VIN location
On a 78, the data plate is on the door face where it latches,not on the jamb
Old Jul 10, 2003 | 07:09 AM
bronco460's Avatar
bronco460
VIN location
Thanks for the replys. My truck has no bed on it to look for a plate rivited to it. It has a flatbed on it. I didn't think that the plate should be on the door jam. But no, it isn't there. I will have to look on the frame.
Thanks to all.
Old Jul 10, 2003 | 11:50 AM
Colossus's Avatar
Colossus
VIN location
Mil1ion, thats kind of what I meant, I just couldn't remember the word "latches" so I just used jamb as a general location.
Old Jul 10, 2003 | 01:39 PM
Mil1ion's Avatar
Mil1ion
VIN location
Think of a house door.
The Jamb is the wood that outlines the door & to which the door is hinged to & closes to.
On earlier trucks at later truck. the data plate and data stickers Really ARE on the door jamb.
Old Jul 10, 2003 | 01:54 PM
Colossus's Avatar
Colossus
VIN location
Thanks
Old Jul 11, 2003 | 11:57 AM
bronco460's Avatar
bronco460
VIN location
Thanks, mine is missing from the door lamb. The frame will probably be my last choice.
Old Jul 11, 2003 | 12:01 PM
Mil1ion's Avatar
Mil1ion
VIN location
On the door jamb near where the door latches, there should be a sticker that can have the VIN# on it too.
Old Jul 11, 2003 | 12:04 PM
bronco460's Avatar
bronco460
VIN location
The sticker is missing from the door jamb. Thanks for your help.
Old Jul 12, 2003 | 10:45 AM
garth's Avatar
garth
VIN location
I have a 76 F-250 4X4 and I found my VIN about six inches back of the passenger side front shock on top of the frame rail. It took a wire brush to make it visible again, as mentioned by mattsbox99.
Old Jul 12, 2003 | 11:59 AM
bronco460's Avatar
bronco460
VIN location
I found the vin on my frame on top just forward of the coil spring.
Thanks for all of your help.
Old Jul 12, 2003 | 01:23 PM
460f250's Avatar
460f250
VIN location
I have the same problem with finding an accurate VIN number because my cab and doors were changed. I haven't as yet found the number on the frame but I do have the tag on the box (if it's the original box). The problem is the numbers on the tag don't seem to be the same as what I'd expect a VIN to be. Is there a different decoder or listing to describe what these numbers mean? This is what my tag says.
ROT6474 Z 5Q 6D D
RT 2HB TS 8FT
F26 FE8954 4T AL2
Thanks for any and all help.
