Steering gear box!
Old May 7, 2002 | 12:53 AM
thoseapples's Avatar
thoseapples
Steering gear box!
&nbsp&nbsp&nbsp The one in my '93 is leaking horribly! It appears to be from the pitman arm shaft seal, on the underside of the gear box. I see part listings for various steering systems seals. Please, someone tell me I don't have to replace the entire $300 gear box over this. Are the box seals removeable and replaceable?
Old May 7, 2002 | 11:45 AM
mantta's Avatar
mantta
Steering gear box!
You should be able to buy a seal kid from Advance or Auto Zone. I replaced the seals in my brothers 87 several years ago and I am quite sure it is still the same steering box. If I remember right there is an upper and a lower seal on that shaft. The hardest part was getting the pitman arm off, regular pullers wont work, you need a pitman arm puller. I straightend out the jaws on a set of regular pullers.
Old May 7, 2002 | 08:12 PM
brett_d's Avatar
brett_d
Steering gear box!
rpaxton939
13
Jul 13, 2014 08:03 AM
MoparMark78
Sep 1, 2010 12:23 PM
fzeed
Jun 21, 2009 11:58 PM
FordTrucksKickGM
Nov 24, 2008 12:22 AM
fomoco
Jan 20, 2003 12:28 PM
