92 f250 electric problem please help
Old Jun 30, 2014 | 11:33 PM
phillyfresh's Avatar
phillyfresh
brand new alternator brand new optima battery checked every fuse every wire I'm getting low amps read still idk what it could be
Old Jul 1, 2014 | 12:01 AM
Evan_P's Avatar
Evan_P
With the truck running what is the voltage at the battery posts? How are the connections? Grounds?
Old Jul 1, 2014 | 08:23 AM
dive2663225's Avatar
dive2663225
may i ask..is it your stock dash guage thats telling you low?? or do you have some other instrument telling you that?
at Idle are your lights dim? but when you increase engine rpm the lights go bright? if your engine is idling at the proper rpm, have you changed any pullys?..the standard alternator must turn at least 1800 rpm at an idle for most of its output Re-pully ratio's
Old Jul 1, 2014 | 09:03 AM
timbersteel's Avatar
timbersteel
Fire prone 2G alternator? Or have you converted to a 3G?
Old Jul 1, 2014 | 10:09 AM
dive2663225
Great Question Timber...as an electrician...i will tell you this.....when the engineers designed that connection on the 2-G...They took..at least 4 tokes too many...
I would like to add...on top of that..probably a good percentage of burn-outs are occurring from the MIS-Use of Dielectric compounds
markeyd
Nov 27, 2015 07:32 PM
tomtoc
Jan 7, 2008 01:03 PM
azu
1983 - 2012 Ranger & B-Series
19
Oct 13, 2007 05:40 PM
bshury
Sep 22, 2005 05:20 PM
racefan1967
Electrical Systems/Wiring
Feb 18, 2003 11:14 PM
