lights dim
Old Feb 16, 2003 | 09:31 PM
racefan1967's Avatar
racefan1967
Question lights dim
I hope some one can give me some answers. I bought yet another Ford truck. It is an 89 F-150 extra cab 4x4 and the question is about the charging system. Now I have checked the alternator and it is puting out 14.69 at idle and it I turn on the lights and the heater blower motor and then put it in gear (yes it is an automatic) the voltage drops and the headlights dim some. Now I have a good battery and new positive and negative cables and can't seem to find any grounds missing. Now I even put in a new alt. to have no change so I put the old one back in. Now my mother-inlaws 88 F-150 2wd does the same thing. Can anyone shed some light on this problem or is just the nature of the beast? See my 67 nor my 76 do that. Thanks Steve
Old Feb 16, 2003 | 09:47 PM
Mil1ion's Avatar
Mil1ion
lights dim
That's normal.
If you want them to go dimmer, put the wipers on too.
I'm sure you raised the rpm to 1000 rpm and V/R kicked in about 750 ....Right?
Old Feb 16, 2003 | 11:01 PM
Mike W's Avatar
Mike W
lights dim
For real dim, go back to a 50's generator. At idle the battery kept things going. Seriously, you might test the alternator to see if it puts out the rated amps.
Old Feb 17, 2003 | 01:48 AM
kioolt's Avatar
kioolt
lights dim
That's normal for Ford pickups. My 93 has been doing that since it was new. An alternator won't put out the rated amps at low rpm.
Old Feb 17, 2003 | 08:15 PM
racefan1967
Thumbs up lights dim
Well that is what I thought. I have tested the alt and it puts out the amp between 750-800 rpm. Thanks everyone I will not worry about it then. I hate to see what it does when I kick on the fog light. Well that all. Thanks again Steve
Old Feb 17, 2003 | 09:09 PM
Mil1ion's Avatar
Mil1ion
lights dim
You could always convert the headlights & Fog light to run off relay's this would make it easier on the headlight switch and provide better illumination.
See the tech article "Whiter White's<> Brighter Bright's"
Old Feb 18, 2003 | 11:14 PM
racefan1967
I am relaying the fog lights but I hadn't thought about the headlights I might have to do that. Thanks Steve
