blown rear axle??
Old Jul 12, 2014 | 09:17 PM
  #31
slowrollerzcustoms's Avatar
slowrollerzcustoms
Redirect Notice
this is the pinion gear
Old Jul 12, 2014 | 09:18 PM
  #32
Buggz_14's Avatar
Buggz_14
The axles look fine.
  #33
OldMetal's Avatar
OldMetal
Also you said the drive shaft spins, is this with wheels on the ground or up on jack stands? And is your truck four wheel?
Old Jul 12, 2014 | 09:21 PM
  #34
Buggz_14's Avatar
Buggz_14
Yes truck is 4 wheel. Drive line spins when truck was on ground and the knuckle spins after I took the drive line out. Yes 4 wheel drive.
Old Jul 12, 2014 | 09:22 PM
  #35
slowrollerzcustoms
the axles are fine the ring gear is fine aim your direction to the pinion gear or the yoke may have stripped the pinion shaft where the yoke is just spinning and not turning the pinion gear
Old Jul 12, 2014 | 09:25 PM
  #36
slowrollerzcustoms
i would be making your buddy pay for his moment of hot rodding a 4 wheel drive truck
  #37
Buggz_14's Avatar
Buggz_14
So how do I find out if its the pinion. My phone won't let me post pics tight now.
Old Jul 12, 2014 | 09:27 PM
  #38
slowrollerzcustoms
http://www.summitracing.com/search/b...odel/ford-9-in
alot cheaper then putting a 3/4 ton axle under it
  #39
slowrollerzcustoms
make sure you match the gears to the front axle
Old Jul 12, 2014 | 09:30 PM
  #40
Buggz_14's Avatar
Buggz_14
Do I need to pull it apart to know for sure.
Old Jul 12, 2014 | 09:39 PM
  #41
slowrollerzcustoms
there is a nut inside the yoke that holds it to the pinion you need to remove that yoke so you can check the splines on the pinion shaft
Old Jul 12, 2014 | 09:41 PM
  #42
Buggz_14's Avatar
Buggz_14
Ok. Thank you.
Old Jul 12, 2014 | 09:43 PM
  #43
Buggz_14's Avatar
Buggz_14
I'll try and post pics.
Old Jul 12, 2014 | 10:40 PM
  #44
Buggz_14's Avatar
Buggz_14
Splins are good
Old Jul 13, 2014 | 06:13 AM
  #45
gatorfor88's Avatar
gatorfor88
Did you read my post above? Check the stub shaft/slip yoke on driveshaft. If it is stripped no amount of rear end work will make the truck move
