One piece glass conversion
Old Jun 30, 2014 | 04:42 PM
Aussie F350's Avatar
Aussie F350
Has any one done a one piece glass conversion on an '80's model F series?
I'm keen to do one on two trucks, one has a two inch top chop and I'm thinking Toyota Rukus windows might fit. The other is a standard height turret.
Would E350?450 one piece glass fit? has anyone tried this conversion?
Cheers,
Rob
Old Jun 30, 2014 | 05:01 PM
Franklin2's Avatar
Franklin2
I know it gives a "custom" look, but I think that is one of the biggest things I miss on the newer vehicles, is the little wing windows.
Old Jun 30, 2014 | 05:11 PM
Diesel_Brad's Avatar
Diesel_Brad
You can't. There is a brace that goes from the outer skin to the inner structure. Without that, the skin will have no support and flap in the breeze
Old Jun 30, 2014 | 06:41 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I know you can swap later one piece doors into a bricknose.
No idea about bullnose trucks, or if the body lines match up.
Old Jun 30, 2014 | 08:13 PM
Diesel_Brad
I gotta hear this.... Since all the 80-97 doors have the brace between the inner and outer shell
Old Jun 30, 2014 | 08:24 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The doors, not the windows.
Those little tabs in my doors have broken so many times I can't count.
Old Jun 30, 2014 | 08:33 PM
Diesel_Brad
You said "you can swap later one piece doors". What are those?
Old Jun 30, 2014 | 10:33 PM
Aussie F350
OK guys,
The brace is not a problem, we have added corner inserts that end up nearly half way to where the bailey channel used to be. The bailey now sits in the corner insert. The corner insert also acts as the mirror mount.
I took some photos of an e350, mid 90's I think, at Dallas airport on a trip to the States. It had one piece glass and the window frames looked the same. It had a corner insert about the same place as I've put mine on the chopped turret. We can finesse the insert to suit.
Just want to know if anyone has done this before I import some door glass.
If I can figure out how I used to post photos I'll get them up.
Cheers,
Rob
Old Jun 30, 2014 | 11:07 PM
Aussie F350
I've put some photos on my profile, it's the only album there. All my old ones have dispeared.
Old Jul 1, 2014 | 04:33 AM
Diesel_Brad
Yes, it has been done, but you need to add quite a bit of structure to the door. look up SPORTTRUK on here. He has yellow truck that he chopped the top, lengthened the cab/frame and used late 90s Ranger windows in
Old Jul 1, 2014 | 07:38 AM
Aussie F350
cool, thanks Brad!
Opossum
Jun 8, 2012 06:37 PM
arrowheadfred
Jul 13, 2011 12:23 PM
maverickman514
13
Jan 3, 2011 12:28 AM
Kongslibakken
Feb 21, 2007 05:38 AM
fyrfyter
Aug 27, 2004 03:42 PM
