'72 Cab VIN Decode
Old Jun 30, 2014 | 02:19 AM
trozei's Avatar
trozei
'72 Cab VIN Decode
I just bought a cab off an FTE user on here and found a VIN tag on the firewall. I've never even heard of this before.
What information is being told here? So far I've digured out that it's a December 1971 F350 chassis/cab with a 9' bed and a 360 that was made in San Jose. Anything else this tag indicates?
What's the 9-377, YA, BDY, 8, LHSM, CUST, Y, and F all mean?
Old Jun 30, 2014 | 11:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by trozei
I just bought a cab off an FTE user on here and found a VIN tag (Buck Tag) on the firewall. I've never even heard of this before.
What information is being told here? So far I've figured out that it's a December 1971 F350 chassis/cab with a 9' bed and a 360 that was made in San Jose. Anything else this tag indicates?
There is no "VIN tag" on any truck prior to 1980. VIN tag located on drivers side of dash, visible thru windshield, has the VIN only stamped on it.
Codes on "Buck Tag" located on firewall used by assembly line workers to make sure installed parts match the build sheet. These codes cannot be decoded.
Warranty Plate located on the left door face below the latch.
Safety Standard Certification Label glued to B pillar below the striker plate.
Cab & Chassis does not come from the factory with any "back of cab equipment." People bought these to install aftermarket bodies.
9' Express Flareside bed available on 1953/72 F350.
December 1971 build date would be a 1972. Since historically new vehicles are introduced in September of the previous year, production begins in August.
Old Jun 30, 2014 | 01:32 PM
HIO Silver's Avatar
HIO Silver
A body "Buck Tag" was used as a quick visual guide for the assembly line without having to refer to the build sheet or warranty plate... it may not have even had a warranty plate when the buck tag was installed.
LHSM... left hand side mirror
Cust - trim level
.. your guess is as good as mine on the remainder.
I don't think tag copy (the text) wasn't standardized so what was used at one plant was not likely used in another. That's why it's not "decodable" by referencing a catalog or manual. It can be decoded rather by a lil deductive reasoning.
Old Jun 30, 2014 | 01:57 PM
trozei's Avatar
trozei
Ah okay, cool. Thanks. I'd never seen a buck tag before so wasn't sure what it was for.
Any idea what these bolts are on the back of the cab? My '69 doesn't even have the provisions for them. I saw these bolts on a '72 F250 as well.
Old Jun 30, 2014 | 02:40 PM
HIO Silver's Avatar
HIO Silver
For the gas tank flange?
Old Jun 30, 2014 | 03:05 PM
NumberDummy
Beginning in 1967, unless ordered with Western Mirrors, all F100/350's came w/an el cheapo standard equipment L/H mirror (C7AZ-17696-A same as 1967/72 cars, LMC calls it by the ridiculous name "Sport" mirror), but it was not factory installed.
It was placed inside the cab at final assembly. Dealers installed all the outside mirrors.
The 'bolt-on' brace is not shown in the parts catalog sheet metal section. It was not used to mount the in-cab tank, since the tank mounted to the floor pan.
1969/72 F100/350's with factory installed in-cab storage compartment:
The optional 25 gallon auxiliary tank was a mandatory order for an obvious reason, since the storage compartment was installed where the tank was located.
This brace may only have been used to mount the storage compartment.
altiric
Large Truck
Jul 30, 2017 03:36 PM
wwhite
Mar 23, 2017 11:47 AM
raycer12
Dec 19, 2015 05:16 PM
scld1354
May 27, 2015 06:29 PM
bremen242
Aug 18, 2003 08:34 PM
