Sponsored by: Auxito
P0171/P0174
Old Jun 29, 2014 | 11:02 PM
Epic-Knightmare's Avatar
Epic-Knightmare
P0171/P0174
Hell all, and thanks for having me. I know this had been said b4, but I am having trouble finding any leaks so far and got good old P0171/P0174..
FF Data:
Fsys1 CL
Calc load 70.6
ECT 94
STFT B1 14.1
LTFT B1 25.0
STFT B2 14.1
LTFT B2 25.0
RPM 2488
SPEED 95KM
Thought the numbers equal on both sides was weird. Didn't happen til I cleaned the MAF. Trying to figure out if it is pump I did install a new one last year also a new fuel filter a month ago. New COP and plugs. problem has been happening since before installing the new stuff other than pump. I did discover an exhaust leak. Gonna try a smoke test to make sure I never missed something but got alot on the go.. Any help would be appreciated..
Old Jun 29, 2014 | 11:09 PM
STOFFERJ's Avatar
STOFFERJ
what did you use to clean the MAF and is everything hooked back up???
Old Jun 30, 2014 | 12:17 AM
Epic-Knightmare
Used some CRC MAF cleaner, (white can) Cleaned and plugged everything back in..
Old Jun 30, 2014 | 07:53 AM
blupupher's Avatar
blupupher
did you just spray it or did you use something to clean it? Mine kept throwing the 171/174 code and I did everything I could (checked all vac lines, cleaned MAF with MAF cleaner ect). Brought it back to the guy that did my engine install and he cleaned the MAF and used a q-tip with mos of the cotton taken off to carefully clean the MAF wires with the q-tip and MAF cleaner.
That was 2 months ago and no problems since. You just have to be very careful since the wires are delicate.
Old Jun 30, 2014 | 12:05 PM
Epic-Knightmare
I have a delicate brush for cleaning electronics that I can use but I never wanted to touch the wires. I cleaned only with the aerosol solution. I am waiting for a new assembly and I am gonna try and purchase an MAF from a scrap yard to see if there is any difference..
Old Jun 30, 2014 | 03:16 PM
blupupher's Avatar
blupupher
Yeah, they are small wires. My mechanic has a few old MAF sensors laying around so if he broke it he would have replaced it.
Old Jul 9, 2014 | 10:56 PM
Epic-Knightmare
Brushed and cleaned, works like a charm.. Got it on some 285's now and waiting for my headers to get here... Thanks alot for the info, sometimes just spraying the MAF sensor isn't enough. I have a new one on the way also but thanks again.. No error codes and got my missing power back..
Old Jul 9, 2014 | 11:16 PM
73fan's Avatar
73fan
While on the MAF subject, what should I be seeing for air flow at hot idle? On a 98 4.6L.
Sent from Nexus 4. IB AutoGroup
Old Jun 12, 2016 | 02:07 PM
junque2k2's Avatar
junque2k2
Check the air filter can for a sloppy large rubber grommet on the bottom side for the IAT/MAF Sensor wires. It's in the right place for an air leak that can throw off the air/fuel mix to cause a lean condition. Mine fell out when I was changing the air filter.
Trevor.801
Feb 19, 2015 10:02 AM
mstng_ray
1983 - 2012 Ranger & B-Series
Sep 12, 2006 09:15 PM
christaylor
1997 - 2003 F150
Jul 16, 2005 07:32 AM
ChucksVan
Aerostar
Jul 29, 2004 08:21 PM
Arkford
Aug 22, 2003 09:48 AM
