Sponsored by: Real Truck
Thanks Krewat
Old Jun 26, 2014 | 08:45 PM
iron1951's Avatar
iron1951
Thanks Krewat
Thank you Krewat for your advice back in 2008. My steering would jump to the left, then to the right, and then would settle down for days. You said jack up the front end and see what happens. I thought it might be a spool valve, but a sticking u-joint showed up. Pointing straight ahead the u-joints looked good but as soon as you turned the wheel the driver's side stuck. Disconnecting the tie rod end and moving the hub by hand, with the axle shaft in the right position I could see why the steering would jump from one side to the other. Because of your advice I learned something new, that u-joints have to be fully free or they will affect the steering, even in two wheel drive with the hubs unlocked. Thanks again.
Old Jun 26, 2014 | 09:08 PM
Bigpipes 35's Avatar
Bigpipes 35
We have an incredible group of people on this forum, Thanks Krewat..
Old Jun 27, 2014 | 06:33 AM
jesse5's Avatar
jesse5
Very good advice Krewat.
Old Jun 30, 2014 | 04:07 PM
Wolfboro's Avatar
Wolfboro
Long time ago , someone (possibly William Shakespeare) said " Better three hours too soon than one minute too late " or , may be "better late than never " in short .
I too enjoyed Krewat's wisdom and diagnostic approach over the years I have been following this forum. But , where is Krewat ? that is the question .
Old Jun 30, 2014 | 04:16 PM
Bigpipes 35
He's around, his last post was 2 days ago..
viperbluelx
Jul 20, 2019 09:55 PM
Preadator
Feb 7, 2017 08:56 AM
100-10x
Nov 21, 2015 01:34 PM
Sycostang67
23
Jan 18, 2010 09:42 PM
Cascarufio
1978 - 1996 Big Bronco
Nov 16, 2003 12:57 PM
