F100/F250/F350 frame and suspension
I have a 1977 F100 with the twin i beam suspension... I need info on 70s ford truck frames.
I have never ridden in a F100 so i dont know how it rides. I also want a little more height to the F100 and since its a 2wd lift kits are pretty expensive and scarce. I dont want anything to big, just a more aggressive stance like a highboy would have. Would f-150-350 frames and suspension be interchangable with the F100 frames in regards to body mounting and such. Thanks-Cole
Plus, if you change frames, in most states, you'll be required to change the registration to match the new frame. So you'll need to get a title with the replacement frame.
They all will interchange as long as the wheelbase is the same. But that's an awful lot of work for basically no benefit. The F100-250 2WD will all have close to the same ride height.
Plus, if you change frames, in most states, you'll be required to change the registration to match the new frame so you'll need to get a title with the replacement frame.
trenchcoatman
11-23-2018 11:32 PM
Gcwstang
19
07-24-2013 06:14 AM
ovrkll77
10-19-2010 03:15 PM
hardway
05-04-2007 04:07 AM
