E-150 Tire Selection - Tread Pattern
Old Jun 25, 2014 | 11:16 AM
Joe Thebeau's Avatar
Joe Thebeau
Hi,
I'm going to replace the Goodyear Wrangler tires I've been running on my E-150 (Avenger Elk Conversion). I've heard that the suspension of these vehicles makes them hard on certain tire tread patterns, but I haven't been able to get details, except for my experience, which has been that these Goodyears are wearing out fast.
Suggestions on a better match of tire/tread pattern for the E-150?
Thanks,
Joe
Old Jun 25, 2014 | 11:00 PM
econolinemanor's Avatar
econolinemanor
Well, the more aggressive tire tread you have the faster they wear, and if they are P rated for Passenger Cars on a Conversion Van they will wear really fast. 02 E-150 should be Rated for LT as in Light Truck and Michelin makes some of the best........... $$$$
Old Jun 26, 2014 | 05:06 AM
JWA's Avatar
JWA
I was going to mention Michelin LTX's as they're my one and only tire choice, without question, I'll never use another brand---ever!
Yes their up front cost seems high but a set I bought new in '08 now has just at 65K + miles on them, a mere 1/4" of tread wear---that's impressive as its 75% of new tread depth. Age alone will necessitate this sets replacement at some point.
I'm not aware an E-Series chassis or suspension is hard on any one tire, assuming alignment is correct and we're not over loading them. I run close enough to my max GVWR of 8,600# as a daily driver/work van yet as mentioned there's no excessive tire wear.
If your E150 conversion is of the later year when the chassis & suspension were essentially E250 specs P-rated tires might be at the root of excessive tire wear. Of course proper maintenance including monitoring of tire pressure also helps tire life.
Along with checking front end alignment I'd weigh this E150 to get a base line for choosing the best load range for your van.
Long story short Michelin are great tires---buy 'em!
Old Jun 26, 2014 | 09:38 AM
Joe Thebeau
Thanks for the tips!
jefflaur1
Transit Connect
13
Oct 4, 2023 03:08 PM
Im50fast
109
Dec 2, 2017 05:20 AM
Tom
2014+ Transit
Nov 27, 2016 09:41 PM
Trumped
Oct 10, 2010 02:08 PM
equium
Mar 4, 2004 08:35 AM
