rear end
Old Jun 24, 2014 | 08:56 AM
renchr56's Avatar
renchr56
rear end
Hello all. I have a 99 e-250 van that the rear went up in... I have a 95 van just sitting here with a good rear in it. Though I know I would at the very least have to replace the driveshaft.. will the 95 complete unit transfer to the 99 with no problems??
Old Jun 25, 2014 | 01:40 PM
blageurt's Avatar
blageurt
I think the 99 is disc brake , while the 95 is drum.....you could probaly swap the Internal parts however....If you do switch them I believe you would need to get the E-brake assembly form a drum brake van as well...I am not 100% on that however....
Old Jun 25, 2014 | 02:04 PM
renchr56's Avatar
renchr56
rearend
No they are in fact both drum brakes... Looks like everything will match up. I did some measurements and all looks good. I don't know if the driveshaft will work though. If not no big deal I will find one that will in fact work... Thanks for the input though.
Old Jun 25, 2014 | 02:43 PM
blageurt's Avatar
blageurt
I do not see how the driveshaft means anything........
Old Jun 26, 2014 | 12:59 PM
Hotairjunkie's Avatar
Hotairjunkie
What are the rear axle codes from the door jamb ID plate for each vehicle?
F-250 WARHORSE
21
Aug 17, 2018 10:44 PM
Tepco
Mar 14, 2018 08:47 PM
pancake52
Jan 22, 2017 03:34 AM
fordman75
Mar 28, 2014 12:13 PM
