05 Expedition Sputtering while driving
Old Jun 25, 2014 | 07:35 AM
jbedsole23's Avatar
jbedsole23
I have an 05 Expedition 5.3 2wd. It seems to be missing when driving but idles fine. I'm not getting any warning lights either. Haven't had a chance to plug in a reader yet but wanted to see if any of you have had this issue. This is my wife's daily driver and she describes it as jumping and hesitating when she gets on the gas. Any help would be great.
Old Jun 25, 2014 | 10:26 AM
alloro's Avatar
alloro
Best to check for codes first, or if your scanner supports live data, hook it up and go for a drive. The live data should give you a misfire count for each cylinder, if any.
Old Jun 25, 2014 | 10:54 AM
jbedsole23's Avatar
jbedsole23
Assuming I cant get live data, what is the best way to check for a bad coil?
Old Jun 25, 2014 | 01:14 PM
alloro's Avatar
alloro
Swapping them one at time with a known good one, then going for a drive to see if it drives any different. Obviously if there are 2 or more misfiring, it get more difficult to feel if it's driving better because it won't drive perfect unless all the misfires are gone.
Old Jun 26, 2014 | 01:34 PM
r2millers's Avatar
r2millers
If it seems to idle fine, but misses on heavy accelerating, I doesn't sound like a COP misfire but rather a fuel supply issue.
How many miles on it? Last fuel filter change?
Ever change the fuel pump?
If not, maybe test the fuel pressure at the rails first?
Old Jun 27, 2014 | 05:10 AM
jbtecnico1's Avatar
jbtecnico1
Mine was spark plugs
Had a 1997 Expedition 4x4 at 106k miles, idled fine but sputtered a little under power. Changed all spark plugs, good to go.
Old Jun 27, 2014 | 10:37 AM
r2millers's Avatar
r2millers
Just goes to show, there could be numerous solutions.
I his case, it sounded like she was really getting on the throttle. With your's, just "under little power" might be the difference to point a certain direction or another.
I've had fuel pumps start to go bad but could only tell when under full power when the system needed max fuel pressure.
DOC1KOC1
Oct 19, 2010 04:21 PM
05FordDerek
Apr 27, 2009 12:19 PM
dmorgan
Feb 10, 2008 05:37 PM
lyonexplorer
Car/truck Buying Advice
Jul 18, 2005 09:42 PM
NutzForTrucks2
Jul 18, 2004 03:44 PM
