Steering Nightmare
Old Jun 24, 2014 | 03:44 PM
Zmills's Avatar
Zmills
Steering Nightmare
I have a 2005 F350 Lariat Super Duty, crew cab, 4X4, long wheel base.
I was driving and lost all brakes and steering at a busy four way stop. Lucky it was 4:00 A.M. no traffic was out because I blew thro red light. investagated first then replaced pump. Steering was good for a very short time brakes did not improve. I replaced hydroboost, was pulling out for test drive and lost brake pedal. Got out and found a brake pad on the ground next to my rear tire. (No prior brake problems or noises to indicate problems.) I replaced rotors and pads bled all brakes again.(First time was when I replaced hydroboost bled steering and brakes.) I have better brakes than when I first bought my truck a year ago. steering is still no good at all I can barley turn the wheel moving at a stop its impossible and I am not a small guy. I checked for leaks everywhere thro the brake and steering system all looks good. I bled the steering again by jacking front of truck off ground, pulled the return line to the hydroboost and turned side to side for a good ten minutes. No changes.????????????????? I am thinking another pump since it was great for a min after replacing first time???? SUGGESTIONS PLEASE!!!!
Old Jun 24, 2014 | 06:43 PM
cheezit's Avatar
cheezit
Drop the arm of the gear box, put the fron axel on stand and see if the steering binds by hand when turning the tires by pushing /pulling on them.. Sounds like a bad gear box more then anything.
Obs7.3Powerstroker
13
Apr 15, 2019 10:28 PM
sleek122
Apr 9, 2016 12:51 AM
Mcrafty1
Jun 24, 2014 05:21 PM
caseys
Sep 17, 2006 10:26 PM
WaltW
17
Apr 5, 2006 09:28 PM
