rapid clicking?????
Old Jun 24, 2014 | 09:08 AM
sport custom 71's Avatar
sport custom 71
rapid clicking?????
I've been having issues the past few days with starting the truck. Plenty of voltage ,but I'll hear this rapid clicking when I turn it over as if there's a short some where, and it won't start. I've gone through and not found anything obvious. Any ideas/suggestions would be greatly appreciated.
Could it be a starter solenoid?
Old Jun 24, 2014 | 09:16 AM
HIO Silver's Avatar
HIO Silver
It could be. Try cleaning all terminals in the start circuit and ground connections and try again.
Old Jun 24, 2014 | 09:33 AM
Redmanbob's Avatar
Redmanbob
Ground
use a pair of cables to make a test ground, battery to block. Most likely need to clean or replace something in the ground circuit.
Old Jun 24, 2014 | 09:48 AM
sport custom 71
Will do, I cleaned all terminals for the two battery system but haven't thoroughly inspected the ground.
Old Jun 24, 2014 | 09:55 AM
orich's Avatar
orich
A lot of guys just pound with a hammer on the top of the terminals with out opening them far enough to seat down on the battery post all the way.
The top part of lead these lead post terminals sometimes get folded over, and only 1/2 way on but this makes the terminals look like it tight.
If this is what yours look like then remove terminals and trim back the smashed over lead flashing from the upper part of the terminals. And clean as OP says or replace as needed.
Also check rear engine to body ground wire is good as these get over looked, or left off when a engine swap have ever been doing.
If theirs a lot whitish acid on terminals replace or clean with baking soda & water mixture to neutralize any acids on or around battery and base battery bracket.
Orich
Old Jun 24, 2014 | 02:15 PM
sport custom 71
Looks as though it was a grounding issue. Cleaned up entire ground system, replaced connectors and hardware. It started right up. I appreciate all the tips. Thanks guys.
Old Jun 24, 2014 | 10:49 PM
orich's Avatar
orich
Okay good, we like closure on these thread posts.
Orich
Dillion Marshall
1978 - 1996 Big Bronco
Mar 11, 2015 10:21 AM
fabieber
44
Jan 19, 2014 12:28 PM
wjjarvis84
Sep 17, 2012 10:22 PM
Rossta86
Electrical Systems/Wiring
Oct 18, 2005 07:51 PM
tlb
Apr 20, 2005 05:21 PM
