F100 Crown Vic 460 Viking Build
Old 08-07-2014, 12:44 PM
pauli3wood's Avatar
pauli3wood
pauli3wood is offline
Originally Posted by Beedub109r
What's the latest?
Moving a little slow the past few weeks, lots of planning. On Tuesday we hit the junk yards and found some suitable inner fenders from a SCAB. It also had a real nice factory exhaust hanger that we will use instead of the cheesy aftermarket style. And then the find of the day were stock valve covers off an old Lincoln. I should have taken a before pic, but here's the after.
We shaved the metal brackets and wire separators and gave them a fresh coat of Ford Blue.
  #77
Old 08-07-2014, 04:30 PM
trozei's Avatar
trozei
trozei is offline
What paint did you use? That looks very nice.
  #78
Old 08-08-2014, 01:42 AM
pauli3wood's Avatar
pauli3wood
VHT Ford Light Blue
  #79
Old 08-08-2014, 02:33 AM
trozei's Avatar
trozei
trozei is offline
Seems pretty close to the Plastikote Old Ford Blue I used on my valve cover. Different lighting and different pictures though. Can never tell without having them both right next to each other.
Attachment 287629
  #80
Old 08-08-2014, 08:39 AM
Beedub109r's Avatar
Beedub109r
Beedub109r is offline
Thanks for the update.
I KNOW how life can get in the way of the important stuff like restoring your ride. Now, I think I'm gonna pull my valve covers this weekend and throw some fresh paint on them. You shamed me into it. Well, here's wishing that both of us have some time this weekend to work on our trucks.
  #81
Old 08-15-2014, 01:06 AM
pauli3wood's Avatar
pauli3wood
Started the Cowl Repair today.
The red cab is rust free and in the best shape we have seen recently. But the cowl has many dents and a nice little "antenna" hole in the wrong spot.
Donor Cowl. Drilled spot welds. Peeling back the first panel.
Close up.
First panel removed.
  #82
Old 08-20-2014, 11:16 AM
pauli3wood's Avatar
pauli3wood
Removed old cowl. Found a fair amount of rust. This will be addressed.
Donor cowl mock up.
  #83
pauli3wood's Avatar
pauli3wood
...so much for "rust free."
  #84
Old 08-20-2014, 12:51 PM
Beedub109r's Avatar
Beedub109r
Agreed
"Rust Free" seems to be a relative term. Looks like you have it on the run though. You've left very few places uncovered at this point that could even have rust. Good work BTW, keep us posted.
  #85
Old 08-20-2014, 03:37 PM
flowney's Avatar
flowney
flowney is offline
This fresh air intake also takes in dirt, leaves and water. Unlike many other vehicles of this and earlier periods, it is always wide open. Dirt and decomposed leaves retain water thereby enhancing and accelerating oxidation (rust).
Thus, I wonder about ways and means of closing this opening off when it isn't needed or at least backing it with a metal screen.
  #86
Old 08-20-2014, 05:17 PM
co425's Avatar
co425
co425 is offline
Donor cowl mock up.
Good time to make sure your door hinge plates are up to snuff as well. Hate to find a stripped hole after having access to remove them.
  #87
Old 08-23-2014, 09:58 PM
Rocknthehawk's Avatar
Rocknthehawk
Rocknthehawk is offline
If you decide to make another set of those radius/control arm brackets, let me know and I'll be the first to buy. A clean and simple solution. I really don't like the brackets I made for my swap.
  #88
Old 08-24-2014, 12:36 AM
TheStuffz's Avatar
TheStuffz
TheStuffz is offline
so far it looks amazing!! hard part looks done. just gotta get the body work cleaned up.
lol the crew cab and bronco in the background looks like a 70's excursion in some photos
  #89
Old 08-27-2014, 01:36 PM
pauli3wood's Avatar
pauli3wood
And then we found this at the junkyard...
I'll take some more pictures in a day or two. Floorpans are pretty much spotless, shiny factory paint in the whole interior. This thing had to have been sitting in a garage most of it's life. Perfect cab corners, cowl is clean and dent free. Just a few small dings on the roof.
  #90
Old 08-27-2014, 01:54 PM
fordcrzymike's Avatar
fordcrzymike
fordcrzymike is offline
Looks clean! That should save you a lot of time and effort.
Quick Reply: F100 Crown Vic 460 Viking Build
