Getting behind instrument cluster?
Old 06-23-2014, 03:03 PM
landers0440's Avatar
landers0440
landers0440 is offline
I want to change my bulbs on the instrument cluster to LEDS but I can't get behind the instrument cluster, I've removed the bezel and everything but I don't have enough slack on the wires to pull the cluster out. How do I get around this issue to gain access to the bulbs?
Old 06-23-2014, 03:24 PM
blackjack33's Avatar
blackjack33
blackjack33 is offline
Did you unhook the speedo cable?
Old 06-23-2014, 04:52 PM
landers0440
I couldn't even get my hands that far back to get to it. I basically took the whole freakin dash apart to get to it from underneath and then found out the PO had jimmy bobbed it all behind there. Problem solved on that now, but I did notice a 3 prong connecter with a green cord and yellow tip that wad plugged into nothing. Any idea what this is?
Old 06-23-2014, 05:33 PM
blackjack33
It's a switched 12V power tap for accessories.
Old 06-23-2014, 09:55 PM
tbear853's Avatar
tbear853
tbear853 is online now
Received 1,301 Likes on 1,101 Posts
Be careful around that speedo / gage cluster housing ..... they can turn to powder.
Old 06-23-2014, 10:40 PM
landers0440
Yeah I've learned that lesson that hard way before. I was changing the lights on the cluster. I want to also change the light that illuminates the temp controls but does anyone know if that is also a 194 bulb?
Old 06-24-2014, 01:39 AM
blackjack33
Yep a 194.
Here's a easy reference chart for you that shows LED bulbs as well...
Link
Old 06-24-2014, 04:40 AM
mebe2k's Avatar
mebe2k
mebe2k is offline
my gauge cluster was turning to powder/brittle and the background of the oil pressure gauge was melted..how I don't know.... a newer/nicer one out of a 1990 Econoline fixed that problem.. looks almost brand new.. the needles are still bright orange..and it was a plug 'n play install..what type of LED's did you use? i'm thinking of doing the same when I get to mine..
Old 06-24-2014, 10:43 AM
co425's Avatar
co425
co425 is offline
All the lights in the clusters are 194's as stated above. 4 led 194's from super brightleds.com work well. Make sure you match colors as well red for red, green for green. Led's are not full spectrum so they will be really dim if you run say white with a red lense. If you change from the stock blue green back light you also need to disassemble the cluster and remove those lenses.
The headlight/washer light is a BA9S bulb the 4 Led barely fits and works there, same with the ash tray light, and the glove box. The heater control light is another 194.
LARIAT 85
32
04-02-2024 07:28 AM
T_Cooksey88
02-25-2017 08:46 PM
hillcountryflt
20
10-26-2014 04:01 PM
redlightning93
Ford Truck Parts for Sale
08-10-2011 11:12 PM
Quick Reply: Getting behind instrument cluster?
