Air Filter Too Small
Old Jun 22, 2014 | 11:18 PM
Macs1964F100's Avatar
Macs1964F100
Is this air filter too small for a stock 292? (1964 2wd 3 spd) I am having problems getting the engine to run lean enough not to soot the side of the truck. Ignition is new, valves adjusted, changed the jets to make sure they were correct, and checked the float level. Idle is adjusted and there is no gas smell at idle, besides the soot pattern indicates it happens while under way. She has a miss sometimes at idle but mostly runs smooth after warm up.
Using the choke, even 1/2 choke, will cause heavy soot to spew on the drive. It occurred to me the small air filter could be causing a higher than normal vacuum which is acting like a choke at higher RPMs. Any thoughts?
enginesmall
Old Jun 22, 2014 | 11:37 PM
85e150's Avatar
85e150
That looks like plenty of filter for your motor.
How about the needle and seat? You checked float level, good. Power valve?
Old Jun 23, 2014 | 12:38 AM
The Masked Rider's Avatar
The Masked Rider
What size CFM carb. It doesn't look stock.
Old Jun 23, 2014 | 08:52 AM
Macs1964F100
The power valve is the only thing I have not checked. Float level is good. I have been assuming the power valve is good based on the ability to stall the motor by turning the idle needle in. This should also indicate the needle and seat is good.
I have not seen a power valve for the pre 64 2100 listed for sale, only the 64 and later. I was going to replace the power valve with the jets but the one I found was listed as 64 and later.
Old Jun 23, 2014 | 08:54 AM
Macs1964F100
It is the correct 2100 with manual choke. Not the original but got the correct part numbered carb off E-bay.
Old Jun 23, 2014 | 09:05 AM
gangstakr's Avatar
gangstakr
Here's my air filter, I don't experience the problem your having. My engine is stock, only difference are the headers.
Old Jun 23, 2014 | 09:18 AM
Macs1964F100
Yours looks like the same diameter but twice as tall. I will look for taller one and longer stud. It is probably not the issue but the filter is 2 year old so I will not feel bad abut getting a new one.
Next I will lower the float a little. If is correct according to the manual but it is still running rich.
Old Jun 23, 2014 | 09:36 AM
critterf1's Avatar
critterf1
Have you tried adjusting with a vacuum gauge?
Old Jun 23, 2014 | 10:36 AM
Macs1964F100
I bought a guage but do not have a port to attach it to. I need to remove the base and drill and tap a port. The soot pattern indicates it is the cruise mixture that is rich. That being said, I cruise mostly at 40 mph with very light throttle. I after changing the jets I took a 40 mile highway cruise and accumulated no soot.
The vacuum test port should be next on my list.
Thank you for the suggestion.
Old Jun 23, 2014 | 10:36 PM
Macs1964F100
What is the part number for your filter or what does it fit. That would save me alot time at the parts store.
Old Jun 23, 2014 | 11:54 PM
gangstakr's Avatar
gangstakr
I'll get the number tomorrow.
Old Jun 25, 2014 | 09:42 PM
gangstakr's Avatar
gangstakr
The air filter I have is a "Fram CA187" It measures 2 7/8 X 9 5/8
Old Jun 25, 2014 | 10:33 PM
Macs1964F100
Thank you for the information. I will pick one up when I get back to town and give it a try.
Old Jul 25, 2014 | 12:27 PM
Macs1964F100
I installed the CA187 and it is the same diameter but twice as tall. I added a stud extension for the bolt. The old was dirty than I thought.
Based on the street dyno of how long she will spin the tire when leaving the house, it is an improvement. 50 ft vs 20. I revved her to 3900 rpms yesterday. Previously, 3600 is the most I would get to. Seams to be breathing better. I have not seen the soot accumulating as bad but have not been driving much. No AC and 100 degrees limits my time in the truck till the evenings.
Old Jul 25, 2014 | 08:35 PM
Shadowrider123's Avatar
Shadowrider123
Size matters
