Sponsored by: Real Truck
trans problem?
Old Jun 22, 2014 | 07:19 AM
stephen217's Avatar
stephen217
trans problem?
The other day i was driving i was driving down the road when suddenly my truck wouldn't shift out of first gear, then the truck died and the motor wont turn over either. Acts like it is locked up. Its an 01 with v10 and 4r100. Just seeing if anyone had any ideas before i tear it apart.
Old Jun 22, 2014 | 10:31 AM
redford's Avatar
redford
FTE Leadership Emeritus
Welcome to FTE, Stephen 217!
Start with taking your serpentine belt off and try to start the truck. It might be your AC compressor has seized.
Old Jun 22, 2014 | 10:43 PM
pappy19's Avatar
pappy19
Is you OD light blinking on your gear shift end?
Old Jun 23, 2014 | 07:00 AM
Tom's Avatar
Tom
That doesn't sound transmission related to me. For that to happen the torque converter and transmission would have to fail together in such a way that's nearly impossible. Sounds to me like an engine problem.
Old Jun 23, 2014 | 07:12 AM
stuart1's Avatar
stuart1
Can you manually turn the engine?
I have seen torque convertors seize in the pump and lock everything up.
Old Jun 23, 2014 | 09:31 AM
stephen217's Avatar
stephen217
The od off lift was blinking a few days ago, the trans cooler was blocked by mud, so i cleaned it out and it never blinked again. The trans fluid smells very burnt but i didnt notice any metal in it, and i have not tried to manually turn the engine yet.
Old Jun 23, 2014 | 10:29 AM
zimm's Avatar
zimm
When my 4r100 blew out in my '03 7.3, it wouldn't go past 3rd gear. I had it towed to Ford and paid for the diagnotic just to make sure it was was the trans. It was. They wanted $3100 for a rebuild. I went with BTS (brian's truck shop) for a custom built trans for about $4500 that is indestructible. Highly recommend.
http://www.brianstruckshop.com/upe_view.php?id=9
dcc1993
Mar 24, 2019 10:53 AM
Kalistoval
May 30, 2014 11:15 PM
Pander
Modular V10 (6.8l)
16
Aug 5, 2013 08:33 PM
mwcoleman
20
Jul 16, 2009 08:42 PM
