Sponsored by: Real Truck
No Dash Lights!!
Old Jun 21, 2014 | 10:32 PM
trent1234108's Avatar
trent1234108
No Dash Lights!!
I just recently (about 2 weeks ago) bout an 04 f250 superduty supercrew Lariet FX4. When I bought it the dash lights did not work. I ignored it figuring that it was just a fuse. After 2 weeks of poking around I can not figure this out. I have read and re-read every discussion related to this problem online. Everyone seems to either have a blown fuse or some other light doesn't work either. I have no blown fuses and everything else is perfectly sound. All running lights, turn signals, interior lights, and gauge information lights work. Just no backlights on the whole dash. There are some loose wires under the dash that I believe are related to the trailer brake controller (not stock I believe) and maybe a small relay looking thing that says "Theft Lock" on it. I am a few days from tearing my hair out and taking it to the dealership and having it tore open. I have not checked the O/D wires like everyone says but I assume a fuse would blow if that was it? When I hit the tow/haul button the "ON" light does illuminate. And I have no voltage or charging problems. If anyone has any idea at all please give me your thoughts. I'm desperate to fix this annoyance by this point!!
Old Jun 22, 2014 | 07:04 AM
projectSHO89's Avatar
projectSHO89
Do you have the adjustment for the instrument illumination turned up?
Do ANY instrument illumination lights work ANYwhere (switches, etc)?
Old Jun 22, 2014 | 08:55 AM
trent1234108
No I don't have any dash lights as far as climate control, switches, or any of the greenish colored lights. My window switches are lit up though if that helps.
Old Jun 22, 2014 | 06:09 PM
projectSHO89
Still need that answered.
Old Jun 22, 2014 | 06:21 PM
trent1234108
Yes, first thing I checked. I'm not totally inapt lol.
Old Jun 22, 2014 | 06:44 PM
Hotpocket's Avatar
Hotpocket
I'm guessing you have park lights because you didn't say anything about them not working. I'm almost positive they are on the same fuse.
Old Jun 22, 2014 | 06:46 PM
trent1234108
Yes as I mensioned I have no other issues at all. Every other light and function work fine.
Old Jun 22, 2014 | 06:52 PM
Hotpocket's Avatar
Hotpocket
Might just be blown out bulbs.
Old Jun 22, 2014 | 06:53 PM
trent1234108
But every single dash light? Excluding the diagnostic type lights in the gauges.
Old Jun 22, 2014 | 06:55 PM
Hotpocket's Avatar
Hotpocket
I think there are only 2 bulbs back there. Has to be something specific to the dash lights if the A/c, radio, steering wheel and door control lights are working.
Old Jun 22, 2014 | 06:58 PM
trent1234108
As listed in previous posts, I do not have climate control lights, 4x4 lights, or any dash light of any kind. Only door lights.
Old Jun 22, 2014 | 08:24 PM
Hotpocket's Avatar
Hotpocket
Well if nothing is working that's the dimmer switch controls that's what I would be looking at.
Hotpocket's Avatar
Hotpocket
May just be a loose connection
Old Jun 22, 2014 | 08:28 PM
trent1234108
I'll check the switch out next time I look at it. The switch will turn on the interior lights on the ceiling.
Old Jun 23, 2014 | 07:10 AM
projectSHO89
Clarity in communicating observations is critical. Ambiguity causes wasted time, money, and effort. BTW, it's actually spelled "inept", not "inapt". Ironic.
Pull out the main light switch and check for power at pin 6, connector C205b (brown wire) when the switch is in either the Park or Headlight position. Inspect that connector pin for damage, overheating, or corrosion.
If power is present, replace the main headlight switch. If not, troubleshoot open circuit between pin 6 and splice S216 (goes back to C206a pin 12).
FYI, the door lock switches don't go through the dimmer, they are switch on or off only.
