egr, head hole, needs threads for ps brackets
Old Jun 21, 2014 | 04:52 PM
Honeybunny85's Avatar
Honeybunny85
hey guys im new here but ive used the site plenty of time for help, but im trying to figure out how to attach power steering bracket bolts to the head where the egr port is , there is no threads there, i dont know where to go to get this part. btw this is on e6se head ,in a 1985 f250 it used to be efi , its now carbed, with a 97 explorer block, 1405 edelbrock, 289 performer intake , mallory 25 unlite , thanks
Old Jun 21, 2014 | 05:26 PM
Franklin2's Avatar
Franklin2
That port is the one for the air pump correct? I thought it just received a plug. I didn't think the power steering bracket when inside it also.
That's the only thing you have to be careful about with a Ford. The heads can be swapped side to side, but if you get them on the wrong side you end up with open exhaust ports in the wrong places, they should be to the rear where the air pump manifold hooked up to them.
Old Jun 21, 2014 | 06:55 PM
Gary Lewis's Avatar
Gary Lewis
HB - I'm not sure what all you said as I couldn't easily read it. But from what Dave said I think I figured it out. The small-block heads are drilled all the way through and the back end gets the AIR manifold and the front gets an insert that provides a 7/16" thread. And that's what your PS pump mounts to. As Dave said, you have to be careful which end goes where, but you can put one of the inserts in if you can find one. IIRC they are 5/8" threads on the outside and the 7/16 inside. Maybe a part store would have them? Or, I might be able to find a Ford # in the catalog if needed.
Old Jun 21, 2014 | 07:27 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
E-Z Lok 329-7 $2.70 each
5/8-11 out 7/16-14 in
Fastenal has them
http://www.fastenal.com/web/products...endingMachine=
Old Jun 21, 2014 | 09:05 PM
Gary Lewis's Avatar
Gary Lewis
Well done, Jim. Finally got to rep you.
Old Jun 21, 2014 | 10:15 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
He says it's an '86 (or later) T-bird head... with no threads.
I thought both 302 & 351 heads were tapped 5/8-11 for the AIR crossover pipe?
Old Jun 21, 2014 | 10:30 PM
Gary Lewis's Avatar
Gary Lewis
I missed that. Maybe it was in that post with no caps and little punctuation. Couldn't read it so was about to move to the next thread when I saw Dave's post.
I don't know about later heads. But from D8 heads through Esomethings they were drilled end-to-end.
Old Jun 22, 2014 | 01:33 AM
f100beatertruck's Avatar
f100beatertruck
The E6's should be drilled through. Either they're backwards or they just need the insert.
Old Jun 22, 2014 | 01:34 PM
Honeybunny85
thanks alot guys i think when i put the heads on they are backwards, but i normally block it , but i need power steering on this one lol
svp_evo
Dec 9, 2013 01:35 PM
Barkin 40s
Dec 29, 2010 07:14 AM
greaseball13
Jan 20, 2006 07:27 PM
RENNIERC
Dec 30, 2005 10:03 AM
lilboysdrivebowties
Mar 29, 2004 09:04 AM
