Okay so one of my dads friends who owns a shop just recharged my A/C system, I've done a R-134a conversion (the cheap little fittings from autozone) that way we could use well R-134a, last year we charged it up but the accumulator collapsed and the old compressor took a dive and locked up. Drove it like that for ten miles and never noticed until i got to where I was going (big opps). So anyways I swapped both of them out and put the whole damn system back together and got him to vacuum it all down and put R-134a in the truck and all that mess and it blows fairly cold, not as cold as the little car that I drive to work most the time or dads truck but cold enough to keep me happy during the evil summers, but I've noticed that when its on the compressor never cycles, Its always running never kicking on and off. I have a new pressure switch on the accumulator and I know it has a screw to adjust it so I'm wondering if I should back it down a little that way it does cycle, or is that even needed? I'm really wondering cause I really don't want a repeat of last year especially with brand new parts. Thanks in advance, Shadow.
Don't have a set at home, I have a little can of refrigerant that has the cold side gauge but that's it and I won't have access to a set I can borrow until Friday of next week. Temp wise I think its around 60 degrees out the vents on max everything and the rpm's held around 2 grand at a stand still. Is it gonna hurt it to be a little overcharged? Cause if so i could try and talk to him and see if he or even I could fix this when ever we can. Gotta get wisdom teeth out next week that's why i can't get to a set until Friday cause I'm gonna be out of it and I'm not paying 60 dollars for a set I might use two times a year. Might see if i can rent a set to give you the pressures if its a big enough issue to need to correct immediately.
Go to search this forum and type in r134a , look for athread by infinite monkeys it is 2 pages and a really good discussion. They are more knowledgeable than I.
Don't hold it to me thats just how i feel it when its idling. now when I took the trash up the road today and used the a/c the truck got darn cold darn quick and felt really good the whole way down the road. But I still plan to get a hold of some gauges and check the pressures. Might of been cheaply done but so far its cost me an arm and a leg to get it to this point so there is no turning back now.
Not sure of your application / what's been done under the hood, but most applications have a A/C Cycling Switch ---normally on the side of the suction accumulator -when pressure inside the accumulator drops the contacts close and the A/C clutch field coil is energized, compressor runs.................when pressure inside the accumulator rises the contacts open and the clutch field coil is de-engerzied and compressor operations stop................
What other components (orifice tube, etc) were changed out when the system imploded? (May have debris, "shrapnel", etc) in places most didn't think they had places...........
Not sure of your application / what's been done under the hood, but most applications have a A/C Cycling Switch ---normally on the side of the suction accumulator -when pressure inside the accumulator drops the contacts close and the A/C clutch field coil is energized, compressor runs.................opposite (contacts close) the clutch field coil is de-engerzied and compressor operations stop................
Accumulator was swapped out because that's what set off the problems for the old compressor in the first place. The orffic tube was changed the last time we got the A/C working (last year but was very warm at the vents) and was changed prior to getting it working with the new compressor this year (for 99 cents you'd be insane not to, will say its a mother of a turd to get out) and like I stated before the compressor had to be changed out to even set this in motion. I do believe that when we messed with it last to figure out the accumulator had collapsed I thing he may of adjusted that Pressure switch up some on the accumulator from where-ever it was set from the box. Also would like to mention that that same pressure switch in question is a brand new part that I purchased because the old one was dead and we just jumped the connection with a wire last year to get it going instead of doing it right.
