Sponsored by: Real Truck
Power windows suddenly stopped working
Old Jun 21, 2014 | 08:41 AM
MaximRecoil's Avatar
MaximRecoil
2004 F350 Super Duty. The engine is a 6.0L diesel (I think ... it is my friend's truck; I know it is a diesel of some sort).
The power windows circuit breaker is fine, but there is no voltage to the terminal in the under-dash fuse block that it plugs into. Using a wire to jump power over from a nearby 30 amp fuse terminal makes the power windows work as they should, so the problem has to be somewhere between the battery and the power window's circuit breaker terminal.
I doubt it is a broken or otherwise damaged wire, which makes me suspect some other component (e.g., relay, module, whatever) that power must go through before getting to the power window circuit breaker. Any ideas where to look?
Bootlegger's Deluxe
Apr 8, 2016 04:50 AM
rnmtenorio
Electrical Systems/Wiring
Sep 21, 2006 04:33 PM
eddings
Nov 23, 2003 05:53 PM
JW 4x4
Jan 5, 2002 11:12 AM
