windstar power windows
Old Feb 8, 2004 | 05:16 PM
rnmtenorio's Avatar
rnmtenorio
Well hello to everyone, I just found this forum and did a search on my problem and still didn't find an answer. Hope someone can help me......
'95 Ford Windstar, none of the power windows work, have checked fuses and relays, nothing. Has anyone had this problem before?
Checked switches for continuity ......
Old Feb 8, 2004 | 09:38 PM
Franklin2's Avatar
Franklin2
Doesn't your power window circuit have a circuit breaker instead of a fuse? Not sure on this one.
Old Jun 26, 2004 | 12:03 PM
shawshank's Avatar
shawshank
95 ford windstar electic window problem
i have the same problem both front door power windows wont work have checked motors they are fine have checked fused and replaced relay and switches for power windows did basic power checks but still have no answer to problem would appreciate help
Old Jun 26, 2004 | 05:23 PM
wrenchturner's Avatar
wrenchturner
i have a 99 and a large fuse under th hood went and i lost the windows, radio and some other crap.
Old Jun 26, 2004 | 07:25 PM
shawshank's Avatar
shawshank
thanks wrenchturner i will check it out
Old Sep 21, 2006 | 12:52 PM
4laneauto's Avatar
4laneauto
Have you found out what is wrong with your Windstar? I have a 95 Winstar also with new fuses and relays,switches,etc. There is no power going to any of them .HELP! None of the windows work at all.
Old Sep 21, 2006 | 04:33 PM
Franklin2's Avatar
Franklin2
I do not have any diagrams of the windstars, but I would imagine they are wired like all other Fords. What I am thinking is the windows go through an accessory delay relay, which lets you operate the power windows with the key off for a minute or two. This relay is controlled by the GEM module which has all sorts of electronic timers and junk in it to do all the fancy functions of the interior lights, windows, door locks, etc.
If you could find this accessory delay relay, and figure out how to jump across the terminals, you could test this theory to see if the windows would start working.
