dipstick
Old Jun 19, 2014 | 11:13 PM
1990-f250's Avatar
1990-f250
dipstick
Okay, this is probably the most stupid situation you guys have ever heard. So I bought a 86 302 and converted it to efi. I put a new timing cover and water pump on, a new intake and all of that stuff, get done and realize there is no dipstick. .. I know stupid. Is there anyway I can drill a hole and put one in anywhere?
Old Jun 20, 2014 | 12:27 AM
Truck Guy99's Avatar
Truck Guy99
If there's no dipstick, your original is probably gone. Just get another from the junkyard. Probably won't be more than 10 bucks and you can be confident it's reading correctly
Old Jun 20, 2014 | 12:41 AM
1990-f250's Avatar
1990-f250
No theres no port for a dipstick. The old port was on the timing cover but I had to swap that for efi conversion.
Old Jun 20, 2014 | 01:09 AM
cbakker's Avatar
cbakker
I assume your in this dilemma because you already have it in the truck? If not, find an oil pan with a dipstick and swap it with yours.
If already installed...
Pull it back out and see above.
Old Jun 20, 2014 | 02:15 AM
Truck Guy99
What cbakker said. I forgot on certain ones it's not on the oil pan. My bad
Old Jun 20, 2014 | 07:09 AM
Conanski's Avatar
Conanski
Ford put the dipstick in several different locations over the years, on the side of the block, in the side of the oilpan, and in the timing cover. Where was the dipstick on the original engine? You should have used the same timing cover and oilpan as was on that motor so that you end up with the same dipstick location, all these parts are interchangable regardless what vintage motor you have.
WA429
Jun 14, 2013 01:05 PM
bill divins
Dec 20, 2009 10:46 PM
c4barnes
Feb 22, 2008 07:13 PM
351foxstang
Jan 25, 2006 11:43 AM
brianfulwood
Oct 27, 2002 10:27 AM
