oil dipstick
Old Jan 24, 2006 | 10:39 PM
351foxstang's Avatar
351foxstang
oil dipstick
can i drill my timing cover to install an oil dipstick on it? my new oilpan did not come with one.
thanks,
carl
Old Jan 24, 2006 | 11:31 PM
MustangGT221's Avatar
MustangGT221
Uh...no...but there's a hole in the block where the original one goes...
Old Jan 25, 2006 | 08:38 AM
klatt_89's Avatar
klatt_89
Depending on if it is a front sump, you could pick up a timing cover that already has the oil dipstick.
Old Jan 25, 2006 | 08:40 AM
MustangGT221
Trucks don't use a front sump, unless he's talking about another app and didn't mention it.
Old Jan 25, 2006 | 09:13 AM
klatt_89's Avatar
klatt_89
On my 73 MerCruiser 302, i have a front sump oil pan, i have to because the axle is towards the rear of the engine, and has hit the rear sump on the 292 y-block. Just depends on your application.
Old Jan 25, 2006 | 10:03 AM
jsutton's Avatar
jsutton
My 77 f100 with a 302 in it has a front sump oil pan with the Dipstick in the timing cover. I don't know if the factory ones have the spot, but on the timing covers that summit sells they state they can be drilled so you can put the dipstick in there.
Jason
77 f100
Old Jan 25, 2006 | 10:55 AM
351foxstang
yeah sorry, its actually going into a 67' mustang. the pan i have is a front sump and there is the extra material on the timing cover for the dipstick.
thanks.
Old Jan 25, 2006 | 11:07 AM
klatt_89's Avatar
klatt_89
If the timing cover looks as i think it does, There is a flat suface on the passanger side, where the dipstick does go through. I was going to do this but i picked up an extra 302 with a front sump oil pan/pickup and timing cover with a timing cover already installed. Depending on the year of the timing cover, there should be a provision for one.
Here is a pic with the dipstick in the front timing cover, hope this helps.
Old Jan 25, 2006 | 11:31 AM
351foxstang
yep, thats the spot i was referring to. thanks for your guys' help.
Old Jan 25, 2006 | 11:43 AM
klatt_89's Avatar
klatt_89
Your welcome, good luck, i have an extra timing cover if you need one that could be drilled.
