Carb issues-what to do
Old Jun 19, 2014 | 09:10 AM
breezesboy's Avatar
breezesboy
I have a 1977 f-250 highboy. I was going to rebuild the 2150 2 bbl carb, but when I took it off I noticed the casting is broken. So now I need to replace it. I plan this fall to build my current 351m into a 400m bored .03 or .04. So my question. What intake and carb should I get knowing that I want to run my 351m this summer, and use the same intake and carb on my build. I had planned to replace intake and carb for my 408m, but never planned to use it on the current 351m. Thanks guys!
Old Jun 19, 2014 | 09:19 AM
HIO Silver's Avatar
HIO Silver
A Weiand Action Plus Intake and a 600 to 650 cfm carb with vacuum secomdaries.
... but start on dual exhaust and headers before upgradimg the induction side of the system.
Old Jun 19, 2014 | 09:25 AM
breezesboy's Avatar
breezesboy
I know its not optimum to do it first but It wont cause damage right? And I forgot to mention I found a pair of aussie heads ill be replacing the stock heads with....does that factor into intake and carb choice? thanks
Old Jun 19, 2014 | 10:04 AM
redroad's Avatar
redroad
I would just repair the 2150 carb by finding a rebuild able core and go .. Stock pile your parts for your build as you can afford them ..
Old Jun 19, 2014 | 10:07 AM
HIO Silver's Avatar
HIO Silver
Yes. the action plus intake is designed for 2v heads.
Old Jun 19, 2014 | 08:28 PM
tbear853's Avatar
tbear853
Edelbrock Performer 400 intake and either #1405 (man choke) or #1406 (elec choke) 600 cfm Performer Carb .... add a Holley 12-803 FPR at 5.5 psi. It'll all work great with the 351M or later on, your 400.
Old Jun 20, 2014 | 10:36 AM
breezesboy's Avatar
breezesboy
OKay thanks for the input guys. I went ahead and just bought a reman Uremco 7-7583. But now im confounded. Its a direct fit but im missing some things on my new carb that were on the old, and have some new things that were not on my old motorcraft. I have a place for a wire to attach to the top of my old one, not on my new, I have a place to attach a wire on my new thermostat, not my old. I have a empty line coming from unter my choke pull off, no idea where it goes and I have added parts to my throttle pump that I don't know their purpose! ill try to post pics but not sure if I can. Need some help
Old Jun 20, 2014 | 12:23 PM
fmc400's Avatar
fmc400
MSEE
See your other thread...
mikeberman04
28
Sep 22, 2007 09:28 PM
lilman320
May 13, 2006 11:35 AM
Searching for answer
1978 - 1996 Big Bronco
Feb 24, 2004 01:05 AM
Brian S
Jan 13, 2003 11:42 PM
