Drivers Side Foot Rest Support
Old Jun 18, 2014 | 08:43 PM
Rick Cargo's Avatar
Rick Cargo
Has anyone out there installed a drivers side foot rest/support? My wife's Mercedes has a dummy like pedal mounted to the floorboard and side panel to rest your left foot on when driving. Its really nice on the longer trips. Does anybody know of a company that makes one for this truck? Thanks, Rick.
Old Jun 18, 2014 | 09:39 PM
Blapensee's Avatar
Blapensee
I've never seen one.. on longer trips i rest my left foot on the door panel bottom cubby. you could try resting it on the parking brake, just don't push too hard but seriously my wife would like something like what you described ill look around
Old Jun 19, 2014 | 06:49 AM
Big-Foot's Avatar
Big-Foot
They are called "Dead Pedals" and there are a ton of them on the aftermarket.. You can buy them from most online parts stores..
Check here at Amazon:
Amazon.com: dead pedal: Automotive
Old Jun 20, 2014 | 05:50 AM
Jigger2020's Avatar
Jigger2020
What Randy said or check your local parts yard........
Old Jun 20, 2014 | 07:11 AM
Map Man 1's Avatar
Map Man 1
I have those in my BMW and they are nice on a long drive....never seen them in a truck.....great idea!
Old Jun 21, 2014 | 11:23 AM
lwk362393's Avatar
lwk362393
I too wish it had a dead plate/pedal. I end up resting my foot on the side of the door near the parking brake and have scuffed it up pretty bad :/
Old Jun 21, 2014 | 03:59 PM
Jigger2020's Avatar
Jigger2020
Just screw a 2x4 to the floor, lol
Old Jun 21, 2014 | 06:35 PM
sdetweil's Avatar
sdetweil
2012's have a foot rest area on the left side. not dead pedal high tho
Old Jun 21, 2014 | 09:44 PM
scar100's Avatar
scar100
I think about this just about every time I drive...just don't remember it when I'm on FTE....I've thought of securing some type of wedge under my mat.
Old Jun 22, 2014 | 08:16 AM
Adobe 11SD's Avatar
Adobe 11SD
Good idea. Now I am going to have to see if I can find something that would work with Weatherbeater floor mats.
Old Jun 22, 2014 | 11:38 AM
jdadamsjr's Avatar
jdadamsjr
Guess it's personal choice since I like as much floor space as I can get...
as it is I have the seat as far back and as far UP as it can go and still not far enough back.
then sometimes this silly seat will actually move forward when I put the key in...
not always, just sometimes... so I have to move it back...
(and yes, have programmed all the remotes since my wife never drives it)
Old Jun 22, 2014 | 12:35 PM
Big-Foot's Avatar
Big-Foot
I would out it all the way up and back, then disconnect the battery for 5-10 mins and reconnect. That should purge all the previous settings (including radio)..
Old Jun 22, 2014 | 04:28 PM
sdetweil's Avatar
sdetweil
Turn off the auto seat setting.
Easy-access/easy-out feature (if equipped)
The easy entry feature can be turned off or on through the vehicle
message center. Refer to Message center in the Instrument Cluster
chapter
The easy entry feature automatically moves the driver’s seat 2 inches
(5 cm) forward when:
•the transmission is in P (Park)
•the key is inserted into the ignition cylinder
(If the seat is located less than 2 inches [5 cm] from the front of the seat
track, the seat will travel up to 1⁄4 inch (6 mm) to the front of the seat
track)
Old Jun 22, 2014 | 05:28 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
I like not having anything in the floor over there, lets me stretch my legs out on a long drive.
Old Jun 23, 2014 | 05:15 AM
Jigger2020's Avatar
Jigger2020
Thats what rest areas are for, lol
hdgapeach
42
Apr 6, 2015 10:22 AM
jmacnwd
Sep 4, 2014 11:29 PM
cv18sro
Escape & Escape Hybrid
Oct 4, 2011 01:09 PM
Onespeed24
Jan 18, 2006 10:15 PM
fatforty
Feb 11, 2002 02:48 PM
