Sponsored by: Real Truck
Insterment gauges
Old Jun 18, 2014 | 07:24 PM
Rickey Joe's Avatar
Rickey Joe
Insterment gauges
I am really hoping that my insterment cluster in not working because my alternator went out at the same time. I really hope they are connected somehow. I really need a wiring diagram for this one. Just got the truck last week and have been taking care of the little things to get it fixed up and make it my own. my new rear step bumper came in today. I will be droping off the the alternator for a rebuild tomorrow. So if someone has a wiring diagram? iamdawntreader@gmail.com
Old Jun 19, 2014 | 05:57 AM
Big-Foot's Avatar
Big-Foot
I don't have access to all the schematics for these trucks but someone who does would probably need a little more information. What year is the truck and is it the F250?
Old Jun 19, 2014 | 01:02 PM
Rickey Joe's Avatar
Rickey Joe
Yes sir....03 f250 5.4L 4 speed automatic. No power windows or locks none of that stuff. BUT after reading the forum for hours last night I have found several occasions where the alternator has effected gauges as it has mine. Fingers crossed I will have my alternator rebuilt sometime within a week and find out for sure.
Old Jun 19, 2014 | 02:18 PM
Big-Foot's Avatar
Big-Foot
My hat is off to you for supporting local business for a rebuild instead of going to Autozone for a Chinese Reman unit that would probably crap out on you next week...
I hope that does the trick Rickey..
Old Jun 19, 2014 | 02:38 PM
jpr38057's Avatar
jpr38057
There is an accessory relay/fuse built in to the cluster that will cause what you are describing. If that is bad you will have to have a new cluster.
Old Jun 20, 2014 | 03:49 PM
Rickey Joe's Avatar
Rickey Joe
Alternator not charging
OK...new alternator in place and still no gauges and I am only getting 11.56v at the batt while truck is running. I had to come to work directly after I installed the alternator. I will do the fuse check when I get home tonight. (I work 2nd shift) Any thoughts or input will be apriciated...
Old Jun 20, 2014 | 04:10 PM
Big-Foot's Avatar
Big-Foot
Rickey - it sure seems like something is wrong with either the alternator or the wiring. While it is running you should be able to measure about 14 volts at the battery. It's not charging..
Old Jun 20, 2014 | 05:05 PM
Rickey Joe's Avatar
Rickey Joe
No it is not charging...I have been reading the forum a lot. I do have a lot of play in the column shifter. I am going to check for ANY blown fuses first then the wiring in and around the shifter. The rebuild kit for the shifter came today so now I can take it all apart and inspect everything up close.
neilc88
Feb 20, 2017 02:07 PM
Lady Sutton
Jan 3, 2013 02:59 PM
polarisman729
25
Jun 24, 2011 09:56 AM
satelliteman38
Electrical Systems/Wiring
May 9, 2010 05:13 PM
Thor69x
Dec 25, 2008 02:50 AM
