Engine swap question. re: Year Differences
Old Jun 17, 2014 | 10:12 PM
lupuseven's Avatar
lupuseven
Short of it is I have an '03 motor, that needs to be replace or rebuilt. Two bad pistons all else is good.
I found an used 06 short block on Craigslist for $600 will it work? Still waiting on response on the miles of that engine.
what are my options otherwise. With a $3k budget?
Long story -
Cyl 8 has a hole in it Cyl 6 is chewed up but nothing there
Shop will rebuild mine for 8k or new/reman form ford installed for 14k. Problem is my credit is crap, I cant get a loan to fix it and I still owe $5600 on the truck. So I am looking at the best possible low rent but safe option for my situation, over the next 2-3 weeks I will have $3k to spend.
original plan was to try and part it out to pay off loan, then get a new loan on another 6.0l. If there are no other options that will be my plan.
thanks guys!
******** charset="UTF-8" src="chrome://hdv/content/hdv.js" type="application/javascript">*********>
Old Jun 19, 2014 | 06:18 PM
Maxium4x4's Avatar
Maxium4x4
Any block will work.... I would opt for a running salvage then have it pulled. I would rather hear, see, before I handed out money.
Old Jun 19, 2014 | 06:37 PM
78fordman's Avatar
78fordman
The hpop oil rails and branch rubes are different between the 2. You will need the 05 or newer wavy oil rails icp sensor pass valves cover to make the 03 heads work on that 06 block
Sent from my leash using IB AutoGroup
Old Jun 19, 2014 | 06:43 PM
lupuseven's Avatar
lupuseven
thanks for the input guys. thats why I asked around before dropping the cash.
still on the hunt :-)
Old Jun 19, 2014 | 07:49 PM
lupuseven's Avatar
lupuseven
Doing some junk yard searches and this came up:
<label for="12">6.0L (VIN P, 8th digit, diesel), ID DG-042-AB thru AD (AT) </label>
<input name="userInterchange" value="F>AD}C}}300}610472" id="13" type="radio"><label for="13">6.0L (VIN P, 8th digit, diesel), ID DG-042-AE, AF & AG </label>
<input name="userInterchange" value="F>AD}A}}300}610473" id="14" type="radio"><label for="14">6.0L (VIN P, 8th digit, diesel), ID DG-044-AA (AT) </label>
<input name="userInterchange" value="F>AD}B}}300}610474" id="15" type="radio"><label for="15">6.0L (VIN P, 8th digit, diesel), ID WG-041-AB (MT, low emissions) </label>
<input name="userInterchange" value="F>AD}E}}300}610475" id="16" type="radio"><label for="16">6.0L (VIN P, 8th digit, diesel), ID WG-041-DB (MT, low emissions) </label>
<input name="userInterchange" value="F>AD}B}}300}610476" id="17" type="radio"><label for="17">6.0L (VIN P, 8th digit, diesel), ID WG-042-AB (AT, low emissions) </label>
<input name="userInterchange" value="F>AD}C}}300}610477" id="18" type="radio"><label for="18">6.0L (VIN P, 8th digit, diesel), ID WG-042-EE (AT, low emissions) </label>
<input name="userInterchange" value="F>AD}C}}300}610478" id="19" type="radio"><label for="19">6.0L (VIN P, 8th digit, diesel), ID WG-042-EG (AT, low emissions) </label>
<input name="userInterchange" value="F>AD}C}}300}610479" id="20" type="radio"><label for="20">6.0L (VIN P, 8th digit, diesel), ID WG-042-EJ (AT, low emissions)
</label>I know I need the AT because of the way it bolts up
but what about the rest for 03 motor?
Old Jun 19, 2014 | 09:19 PM
Maxium4x4's Avatar
Maxium4x4
If you ever do run into a block, carefully inspect the entire thing. No cross hatch in the cylinder wall, pass on it. I have several owner crashed vehicles around me that one can purchase, hear it run, for $3500.00. One is rolled, the other was direct front hit with extensive frame damage.
Old Jun 19, 2014 | 09:37 PM
lupuseven's Avatar
lupuseven
Cool thx!
once I get the loot rounded up I will get a hold of you
Old Jun 19, 2014 | 09:58 PM
F350 1990's Avatar
F350 1990
Long story -
thanks guys!
An option is to look around at govt, commercial auction sites that have International VT365 equipped trucks (e.g 4200).............many times these badly beaten up vehicles (e.g box trucks) have decent engines and go cheap..........you'll need to bring your electronics, emissions, upper end, etc because the VT365 is "simpler" (and less trouble than the early 6.0s).......
Old Jun 20, 2014 | 12:47 PM
lupuseven's Avatar
lupuseven
Awesome idea thank you!
Old Jun 20, 2014 | 06:22 PM
cheezit's Avatar
cheezit
3500 should get you pretty close to a running engine fromna bone yard.
Rusty_S
Jan 8, 2015 09:38 PM
just another truck
Sep 18, 2008 12:17 PM
Jocaren
Mar 8, 2008 11:37 PM
rpjbfoster
Mar 11, 2006 06:29 PM
74crwcb429hibPS4spd
Apr 20, 2003 10:41 PM
