I just ordered some pins to rebuild the shackles on the front of my f1. The original pins were splined into the shackle plate. The new pins do not have splines. Are all the reproduction pins made without splines? Any issue using the repop parts?
here is a picture of the pins that came out of the shackle end only.
now that it is loaded, i can see how bad this photo is. anyway you can see the impression that the pin left inside the shackle
Pictures help, thanks. Maybe someone else knows better but IMHO I don't think that it makes much difference. The only thing that is not symmetrical about that part is the grease hole. I think that lube can get through wherever it is pointed.
As for those pins being worn they are not too bad. Here is a picture of bad:
