Ds2 swap info please
Old Jun 16, 2014 | 07:07 PM
JayzDaddy's Avatar
JayzDaddy
Guys with taxes im going to do this swap. Ive been reading lots of info about this and am thinking of going with the gm hei box. Does anyone have a step by step with photos? I think i understand everything. My biggest thing is access to a yard with parts. Local yards just dont have many of these trucks/cars and im at a loss at what to do for the dizzy connector. Also eliminating the lines and emissions pieces and computer. I understand better if i can see whats being done as well as read it.
If anyone has, knows where, or will do these pic, i would greatly appreciate it.
Old Jun 16, 2014 | 07:27 PM
roadrash63's Avatar
roadrash63
Convert your Ford to GM-HEI Power the easy way and gain some horse power to boot.
A lot of guys when converting from fuel injection to carb use the Duraspark II system. This requires pulling out the TFI distributor and coil and replacing them with the Duraspark distributor, coil, module, starter solenoid, and ballast resistor. Yeah its complicated and can get spendy but what else is there besides an even spendier aftermarket system? Well, if you don't mind a little cross breeding you can use a GM HEI ignition module. All that's required is a Duraspark distributor, HEI module, and coil. Because of the dwell control and current limiting circuits of the HEI you can use just about any coil you want, including the TFI coil, and no ballast resistor is needed.
If you are converting from fuel injection all you will need to buy is a Duraspark distributor, HEI module, and some wire and connectors to hook it all up. The cheapest place to get the Duraspark distributor is at a junkyard or swap meet, usually $20 or less. Duraspark distributors came on Ford cars and trucks from the mid seventies through the mid eighties. You could also get a rebuilt one at the auto parts store, generally $40 or more. Be sure you get one for the same model engine you have, many of them look very similar but are not interchangeable. On some engines, like the 302, you need to match the gear material to the camshaft you are using. Flat tappet cams use a cast gear where roller cams use a steel gear. If you look at the shank above the teeth a cast gear will be a rough cast finish where a steel gear will be a smooth machined finish. If you want a small block distributor with a cast gear tell the parts guy you want one for a 5-speed '84 Mustang GT. For a steel gear tell him you have a 5-speed '85 Mustang GT. If the guy at the parts store has two distributors listed and doesn't know which is which, the one with the cast gear is always considerably cheaper than the one with the steel gear.
Forinhand.jpg (6492 bytes) the module you want a GM 4-pin HEI. They came on GM vehicles from the mid seventies through the early eighties. You can buy one new at any auto parts store. Any good parts guy will know exactly what a four-pin HEI module is. Although good parts guys are hard to find so you will probably need to ask for an ignition module for a '78 Camaro with a 350. Since they are so cheap you don't need to go to the junkyard. Besides, all the junkyards around here wouldn't even sell me just the module, they wanted me to buy the whole HEI distributor to get it. The module in the picture is a Car Quest #21040 and cost me $17.77. As you can see there are four pins labeled W, G, B, and C. The G pin is a 3/16" (0.187") male quick disconnect and the rest are 1/4" (0.250") male quick disconnects. I recommend you stay away from the Parts Master module #LX-301. All the failures I have seen and heard about were due to the Parts Master module.
The HEI module gets pretty hot, whatever it's mounted to needs to act as a heat sink and carry heat away from it. Mount it securely to a flat metal surface away from the headers or other heat sources. There are two pins on the back of the module that you need to break off so it will sit flat. The module will come with some heat sink compound, smear it evenly over the back of the module before bolting it down. The compound aids heat transfer. You could also mount the module to a big heat sink. I bolted mine to a heat sink from a slot type computer processor. If you're a computer geek like myself then you probably have one laying around. If not then you can buy one at Radio Shack or a computer store. Again you will want to use the heat sink compound between the module and heat sink.
Once you have it mounted you need to wire it up. The B pin goes to the positive coil lead which gets power when the key is on, and C goes to the negative coil lead. The tach. hei2.gif (2666 bytes)also hooks to the negative coil lead. If you are converting from fuel injection then the coil is already wired for power (red) and tach. (green). Splice into these wires. Don't remove them from the coil just addplug.jpg (2944 bytes) some wires to them and run them to the module. On an older car you will need to bypass the ballast resistor so you get full power to the coil and module. The Duraspark distributor has a funky three pin connector. You can just plug into it with standard 3/16" female quick disconnects. The purple wire is run to the G pin on the module, and the orange wire is run to the W pin. Run the black wire to one of the mounting screws on the module. The black wire provides a solid ground connection for the module. The module must be grounded or it will not work properly.
Like I said before you can use just about any coil you want. Basically the only coils that you can't use are aftermarket coils which are for CD (capacitive discharge) ignitions only. I recommend the TFI coil, its the square looking coil used on fuel injected Fords. They are dirt cheap and work great because they were designed for the Ford TFI which is basically the same thing as the GM HEI. If the TFI and HEI modules are the same then why can't I use the TFI? The TFI distributor uses a Hall sensor instead of a magnetic pickup so the TFI module will not recognize the "analog" signal from a Duraspark distributor. However, you could hook a TFI module to breaker points since they put out a "digital" signal like the Hall sensor. No matter what coil you use you will not need a ballast resistor. The purpose of a ballast resistor is to add series resistance to limit current through the coil. The HEI actually measure the current and when it reaches a certain point resistance is added using the switching transistor to prevent excessive current draw. So basically it has a built-in self adjusting ballast resistor.
That's all there is to it. Whether you are converting from fuel injection or piecing together a weekend warrior the HEI is hard to beat. Its easy, cheap, and a great performer. You could spend five times more on an ignition and chances are you won't see much, if any, improvement.
If you have any questions or comments write me at mrriggs@gofastforless.com
Old Jun 16, 2014 | 09:29 PM
JayzDaddy's Avatar
JayzDaddy
Yup, i have the dirt cheap ds2 page favorited too.
Old Jun 16, 2014 | 09:44 PM
Russ85F150's Avatar
Russ85F150
Wow. I think ill start acquiring parts for this conversion on my 85. I was gonna have to wire in a new harness to the distrib to fix all the broke wires but this looks like what ill be doing instead
Old Jun 16, 2014 | 10:05 PM
Rusty_S's Avatar
Rusty_S
good alternative, but for me I always cringe at crossbreeds. We are building one at work a 1956 F600 cab on a 1999 Dodge extended cab dually frame. I wouldnt have a problem canabilizing parts off a newer vehicle long as its the same make thats just me.
sixofspades
33
Dec 25, 2023 10:28 PM
sixofspades
Feb 14, 2014 08:23 PM
daveengelson
Mar 10, 2004 07:13 PM
chipper
Dec 30, 2003 08:19 AM
f100guy
Electrical Systems/Wiring
Dec 19, 2003 07:36 PM
